cozza_mane Posted September 17, 2010 Report Posted September 17, 2010 Got a leak and want to figure out the gearbox I'm might have, i have an ae82 4age in my ke55 i think and I'm guessing its the t50 but want to know where i can check, and also I want to find out where the cable or whatever is for the reverse lights as they do not work. i cannot find a cable on gearbox and need them working for the blue slip uhh Quote
Evan G Posted September 17, 2010 Report Posted September 17, 2010 it would be a t50 if its sitting behind a 4age, do a dodgy and wire in a on/off switch for the reverse lights? Quote
Trev Posted September 17, 2010 Report Posted September 17, 2010 As evan said, most likely T50. IIRC the reverse light switch is on the passenger side of the gearbox, may not of been connected. Quote
Taz_Rx Posted September 17, 2010 Report Posted September 17, 2010 And its just a couple of male bullet terminals hanging out of a big bolt looking sensor. There should be wires in the engine bay from the stock GB reverse switch. Quote
cozza_mane Posted September 20, 2010 Author Report Posted September 20, 2010 cheers guys, can't manage to find it yet, but being a moron as usually I'm checking at night and trying to crawl under, il jack her up after work tomorrow and have a proper look Quote
cozza_mane Posted September 21, 2010 Author Report Posted September 21, 2010 anyone have connection for reverse lights? il post up a pic of what I think it is, I found on the passenger side Quote
