brendan Posted September 1, 2010 Report Posted September 1, 2010 hi all i heard a ke20/25 diff fits straight into a ke17 is this true? if not does the centre atleast fit ? any help would be much appreciated cheers Quote
terryo Posted June 18, 2011 Report Posted June 18, 2011 did you ever get this sorted. i'm looking at same thing thanks, terry Quote
tojo2 Posted June 18, 2011 Report Posted June 18, 2011 center fits if theyre jap diffs, ke17 is narrower Quote
Jono.C Posted June 18, 2011 Report Posted June 18, 2011 It wont go straight in, well into a ke10 anyway, you need to move mounts Quote
GJM85 Posted June 18, 2011 Report Posted June 18, 2011 You really need to look at the wheel track of the vehicles. If the wheel track is wider in the rear then you can guarentee the spring mounds will be wider, which is one problem. The shock absorber mounts on the diff is the other problem. I was caught by a rumour that ke55 diffs bolt straight into ke20's. Not so. Quote
