is it your points?
Check vacuum hoses too... I was doing reversies in a ford laser when i was younger and a vacuum hose popped off some how, engine cut out and i spent ages trying to figure wtf happened only to find a loose vacuum hose. plugged it on and it started up again
Where doesn't it spark??
Do you have power to the coil?
Do you have power to the points?
So if you turn the motor by hand with the ignition on and the dizzy cap off can you see the spark when they open?
Either a wire fell off, or its broken inside its insulation.
Mate, I just couldn`t help myself. When you`ve got the powaaaa ya just gotta use it.
Actually it was a 61 notch back anglia that I slotted a 1500 cortina into. Had head, cam extractors and quad honda 750 carbs and used to go really well. Stopping and body roll was just a bonus.
Cheers.
OMG!! Lookout! Ruunnnn....
Chin which lead do you mean?? The high-voltage lead from the coil to the dizzy or the low-voltage lead from the coil to the dizzy??
Turn on the ignition, take off the dizzy cap and open the points with a flatblade screwdriver a couple of times. You should see a spark. Let us know.
Chin, open the dizzy cap and get someone to hit the starter and see if the contacts of the points open and close. If you have trouble i can always drive down and help you, if it comes to that.
Did you use a toilet brush to wipe the skid from the bowl? :hmm:
hehe i actually laughed out aloud when i read that.
just becareful doing this, i used an allen key to do this last time, got a nasty shock from the coil! my hand/arm was not the same for the next few hours!
(note, don't try and adjust the points when the IGN is on)
make sure you use something insulated!!!
also make sure you havent got any moisture inside the dizzy cap, was it raining when you were doing a skid
Edited by ke70dave
