curly Posted September 1, 2010 Report Posted September 1, 2010 so we don't clog up someone elses thread is this achievable, before you laugh have a think and come up with a thought on how to make this possible, My thoughts, TO4Z garrett mechanical fuel injection nitro methane for fuel 35% fuel to air mixture 18/1 compression ratio cams, valves, springs, ports, pistons, rods, crank, to allow for about 20000rpm i think you would need about 350kw flywheel to achieve this possible or not? Quote
ke70dave Posted September 1, 2010 Report Posted September 1, 2010 why mechanical fuel injection? i can't comment on the rest though. Quote
Twinky Posted September 1, 2010 Report Posted September 1, 2010 don't forget to add that flux capacitor for the extra 1 gigawatt of powar! Quote
curly Posted September 1, 2010 Author Report Posted September 1, 2010 ke70dave said: why mechanical fuel injection? i can't comment on the rest though. i don't think you could get enough fuel in with injectors, i'm thinking when the chamber is fully compressed it will be a third full of fuel, same as a top fuel car Quote
snot35 Posted September 1, 2010 Report Posted September 1, 2010 I don't think anyone could probably say for sure on this one, with no one having tried it, but 20000rpm is F1 territory, and having seen some F1 engine gut photos, I'm thinking you'd need to do a lot of work to get there. I'm thinking the piston speed to get up there would probably be too high, and you'd actually want a shorter stroke combined with some very trick pistons, rings, rods and crank.. I'd also be curious to know if the block would hold up to it. I'd say you'd want some pretty good block modification to make sure it survives. Maybe sleeves, or extra support at the very least? Quote
ke70dave Posted September 1, 2010 Report Posted September 1, 2010 had a play with programs such as this? http://www.virtualengine2000.com/index.htm prolly not a bad way to estimate power from these mods. Quote
Taz_Rx Posted September 1, 2010 Report Posted September 1, 2010 snot35 said: I don't think anyone could probably say for sure on this one, with no one having tried it, but 20000rpm is F1 territory, and having seen some F1 engine gut photos, I'm thinking you'd need to do a lot of work to get there. I'm thinking the piston speed to get up there would probably be too high, and you'd actually want a shorter stroke combined with some very trick pistons, rings, rods and crank.. I'd also be curious to know if the block would hold up to it. I'd say you'd want some pretty good block modification to make sure it survives. Maybe sleeves, or extra support at the very least? Interesting thing you just made me remember - Yes a f1 engine can do 20,000rpm , but it does so with a very short stroke. A top fuel drag car only does 9000rpm, but the piston moved like half a foot in its stroke. This actually means that the top fuel engine has a faster piston speed than and F1 engine. From memory @ 9000rpm the piston is doing something crazy like 170 strokes per second!!! :jamie: Quote
ke70dave Posted September 1, 2010 Report Posted September 1, 2010 Taz_Rx said: A top fuel drag car only does 9000rpm, but the piston moved like half a foot in its stroke. This actually means that the top fuel engine has a faster piston speed than and F1 engine. lucky they are using forged aluminium conrods. how cool is this. http://www.bmeltd.com/rods.htm Quote
cuzzo Posted September 1, 2010 Report Posted September 1, 2010 You would need to sleeve the block aswell as grout fill the water galleries. Dry sump etc You could only run it for one run untill it starts to get too hot. Even then i think the block would still find a way to make it the first boxer 4age out there. Quote
beerhead Posted September 1, 2010 Report Posted September 1, 2010 GT35/40 on 10psi on a Haybusa motor makes 400hp at 15,000rpm, tuned in brissy too. Nothing till 9000rpm then all hell breaks loose. So yep - If you can rev it hard it enough it'll spool. Mech injection pumps straight to the cumbustion chamber and you get no detonation at hideous compression ratios. Add this to purchase order - - Monoblock copy of a 4AGE in titanium head to sump - headgaskets are for chumps. - 20,000rpm will need a desmodromic valve train from a ducatti or pneumatic valve springs, F1 motors only go to 15K on springs - call ferarri or cosworth and ask for a quote I dare you :jamie: - Fully sequential dog box that'll take 20,000rpm shifts - Maybe a more expensive turbo with fancier bearings is in order. Quote
cuzzo Posted September 1, 2010 Report Posted September 1, 2010 (edited) beerhead said: GT35/40 on 10psi on a Haybusa motor makes 400hp at 15,000rpm, tuned in brissy too. Nothing till 9000rpm then all hell breaks loose. So yep - If you can rev it hard it enough it'll spool. Mech injection pumps straight to the cumbustion chamber and you get no detonation at hideous compression ratios. Add this to purchase order - - Monoblock copy of a 4AGE in titanium head to sump - headgaskets are for chumps. - 20,000rpm will need a desmodromic valve train from a ducatti or pneumatic valve springs, F1 motors only go to 15K on springs - call ferarri or cosworth and ask for a quote I dare you :jamie: - Fully sequential dog box that'll take 20,000rpm shifts - Maybe a more expensive turbo with fancier bearings is in order. Youd probably need some good quality oil with the monoblock.....something like magnetec where the oil sticks to the top of the motor to stop it getting damaged on cold starts. Edited September 1, 2010 by cuzzo Quote
curly Posted September 1, 2010 Author Report Posted September 1, 2010 The rules for this are, no $ rev or capacity limit just 7psi and it has to be 4a based, i don't think you could get enough air in to produce that horespower Quote
Twinky Posted September 1, 2010 Report Posted September 1, 2010 so don't use plain old air, just nitro. Quote
SLO-030 Posted September 1, 2010 Report Posted September 1, 2010 Prius + 1.21 Gigawatts > 280kW 4age :hmm: Quote
Trev Posted September 1, 2010 Report Posted September 1, 2010 beerhead said: GT35/40 on 10psi on a Haybusa motor makes 400hp at 15,000rpm, tuned in brissy too. Nothing till 9000rpm then all hell breaks loose. So yep - If you can rev it hard it enough it'll spool. A Busa also has a stock power output of 180 - 200hp so you are only having to double it. Quote
