rockcox Posted August 28, 2010 Report Posted August 28, 2010 Hi all, Just replaced brake pads, shoes and fluid on my housemate's 1988 AE82 Seca. Bendix bs1602 shoes (right) have about 5mm less width than the ones that came off. No drama, my parts guy said it's OK and that they probably use a different compound that gives the same stopping. Not that the rears do much anyway. The only thing is if they ever get replaced again the drums may need machining..... having said that, the brakes will probably outlive the car. what was more worrying and annoying was that the shoes didn't fit into the adjusting slots properly I had to file a bit off the slot (bendix on the right) so that they seated all the way. New parts on old cars; you always need to modify something. Quote
LowVp Posted August 28, 2010 Report Posted August 28, 2010 i replaced pads on my brothers vz r8 and the pads i pulled out were ferodo but the replacements were the same deal, same size backing plate put the pad area was smaller Quote
Trev Posted August 28, 2010 Report Posted August 28, 2010 Not 100% sure but I believe that you needed BS1379. Quote
LowVp Posted August 28, 2010 Report Posted August 28, 2010 http://bendix.com.au/catalogue/10158#variant Quote
Trev Posted August 28, 2010 Report Posted August 28, 2010 http://bendix.com.au/catalogue/10158#variant According to brakepads.com.au AE80 brake shoe = BS1602 AE82 brake shoe = BS1379 And if you search bendix for BS1379 it will come up as a Datsun 120y shoe which is 35mm wide which is where you have lost your 5mm over the BS1602. Quote
rockcox Posted September 1, 2010 Author Report Posted September 1, 2010 According to brakepads.com.au AE80 brake shoe = BS1602 AE82 brake shoe = BS1379 And if you search bendix for BS1379 it will come up as a Datsun 120y shoe which is 35mm wide which is where you have lost your 5mm over the BS1602. My Housemate says "well they work..." Quote
rockcox Posted September 5, 2010 Author Report Posted September 5, 2010 According to brakepads.com.au AE80 brake shoe = BS1602 AE82 brake shoe = BS1379 And if you search bendix for BS1379 it will come up as a Datsun 120y shoe which is 35mm wide which is where you have lost your 5mm over the BS1602. Just a thought, Would it be worth creating a thread or discussion board to identify incorrectly listed parts and, once confirmed, for a moderator to officially contact the manufacturer on behalf of the group and have their listings changed? How many ae82 owners know that they need to order 120y shoes? Quote
Trev Posted September 5, 2010 Report Posted September 5, 2010 Just a thought,Would it be worth creating a thread or discussion board to identify incorrectly listed parts and, once confirmed, for a moderator to officially contact the manufacturer on behalf of the group and have their listings changed? How many ae82 owners know that they need to order 120y shoes? Not even sure if it is correct though but with the mistakes I have found in the bendix catalogue I would not be surprised. Maybe you could call the local parts suppliers and see who has a set of BS1379's in stock and match up the old pair, if you can't then I will when I change the Mr's car from drums to discs. Quote
rockcox Posted September 12, 2010 Author Report Posted September 12, 2010 Not even sure if it is correct though but with the mistakes I have found in the bendix catalogue I would not be surprised. Maybe you could call the local parts suppliers and see who has a set of BS1379's in stock and match up the old pair, if you can't then I will when I change the Mr's car from drums to discs. OK Trev, will do that. Bendix also list the 1602 for my AE95 so I may have problems there too. What do people think about my parts listed incorrectly idea? Quote
