  Trev said:
So you are saying that a 40 weight is thicker then a 80-90?
If it is using oil then try Penrite HPR50.
  tojo2 said:
75 w gear oil is about the same viscosity as 10 w motor oil
http://www.bobistheoilguy.com/cms/index.ph...8&Itemid=55
FFS, some of you c**ts annoy me, did I say 40 weight is thicker then 80-90 weight or 80-90?
I said so you are saying that you think 40weight is thicker then 80-90 gear oil which if you look at the chart it isn't until it heats up.
If your looking for a solid oil that minimized smoke but still gives a relatively good visc rating Gulf Western Engine Extender is the shit... 25w60
