caster makes everything better. the limiting factor is when your arms arnt strong enough to turn the wheel...
Camber, depending on use and how much you care about your tyres on the road you shouldnt need any more then -3degrees but maybe 1.5 to 2 might be better on street stuff..
and with toe for street 2mm out is fine. track only car weve had v8 supercars around 10mm out sometimes but around 4-6mm out should do the trick zero or in will make it twitchy in a straight line. i ran like 8mm out on my ke70 at its last outing at winton.
Where are you measuring from to get the numbers 2mm? Edge of the rim? I did my alignment with string lines and jut set the toe to zero. How will I benefit from more toe out?
Edited by GREESR
