Des Posted December 27, 2011 Author Report Posted December 27, 2011 if your looking to run extractors, use a ke70 starter motor as the solenoid is closer to the block and more clearance between the exhaust and solenoid We want to eventually but for now ke11 manifolds will do. Quote
GJM85 Posted December 27, 2011 Report Posted December 27, 2011 :rocknroll: ʞ©$ɟenyes! Quote
philbey Posted January 1, 2012 Report Posted January 1, 2012 Hm/perry headers fit with all the different starter motors- ke70, original ke10, reduction gear starter. Trust me I've changed 3 this year haha. Quote
Des Posted January 2, 2012 Author Report Posted January 2, 2012 Hm/perry headers fit with all the different starter motors- ke70, original ke10, reduction gear starter. Trust me I've changed 3 this year haha. Thanks for the tip. Quote
Des Posted June 30, 2012 Author Report Posted June 30, 2012 Got a hi torque starter from Red the other month and got 4 carbies to go on the 5k too. Going to move the ke11 into a better position in the shed for more light and space. Quote
Des Posted May 18, 2013 Author Report Posted May 18, 2013 The Ke11 is still in the shed and still hasn't moved since it was put in the shed. I'm keen to get it going soon though. Things to do for RWC: Convert to ke20 disc's. Fit 5k starter motor. New wheel cylinders, linings and maybe drums on the rear. Service the toyoglide and see if i can find a selector shaft seal. Clean out radiator. Quote
