jono1986 Posted August 3, 2010 Report Posted August 3, 2010 http://www.lucasinjection.com/Triumph%202.5%20page%201.htm Quote
towe001 Posted August 3, 2010 Report Posted August 3, 2010 Bugger the Aisin modification, get a throttle body from an EA falcon if you want bolt on injection. They use the Weber bolt pattern so your adapters will work too. Yup, thought of that already 3k Diy Stealth Efi Setup, Can you see my efi??? unfortunately i can't get to those ebay links from work... http://www.diyautotune.com/catalog/megasqu...-kits-c-30.html but these guys are pretty decent prices 253US for the kit (277AUD) or 411US for one that is already assembled. (450AUD) From what i can figure there's not really much difference between the megasquirt I and megasquirt II apart from the kit starts from $145US $187US for the lot http://www.diyautotune.com/catalog/megasqu...d-kit-p-46.html It'll work with the relutor style dizzy or delete the dizzy and go dizzyless <snipe>worth it on a stock 5k? i say hell no:P Yes and no negative is the cost outlay positive is the maintenance side positive is also that being programmable is the easy of upgrades. Cam change - redo the map. Can also plug an old PDA into it as well for on the road changes, EG crap fuel. Quote
jono1986 Posted August 3, 2010 Report Posted August 3, 2010 Also the main reason i want to do is you turn the key and go, no worries about choke or throttle control. And the maintenance side, i'm over carby too much work. Quote
ninja-philbo Posted September 4, 2010 Report Posted September 4, 2010 anyone wanna set a mega squirt up for me lol Quote
