Zoidburg Posted July 29, 2010 Report Posted July 29, 2010 Hi everyone, I'm currently rebuilding a 5K and have a standard twin carb set up, but think fuel injection would give better performance. Does anybody know where I can find an EFI set up for it? Thanks very much. Quote
white_sandshoe Posted July 30, 2010 Report Posted July 30, 2010 Zoidburg said: Hi everyone, I'm currently rebuilding a 5K and have a standard twin carb set up, but think fuel injection would give better performance. Does anybody know where I can find an EFI set up for it? Thanks very much. Right here... The answers you seek... or here... D'OH! That'll give you an idea of where to start looking. Quote
greenmac80 Posted July 30, 2010 Report Posted July 30, 2010 you could possibly build your own inlet and efi system. www.efihardware.com Quote
greenmac80 Posted July 30, 2010 Report Posted July 30, 2010 on that website you can even get a k motor manifold. dcoe throttle bodies. ecu.. the works.. expensive but could work out to be far superior to standard 4ke injection. Quote
Zoidburg Posted August 1, 2010 Author Report Posted August 1, 2010 Thanks guy's. I do know how to work the search function, and have read all the articles before. Guess I just overlooked building my own EFI system. Reckon I'll go to the EFI Hardware site and take it from there. Cheers :lolcry: Quote
jono1986 Posted August 1, 2010 Report Posted August 1, 2010 If you can weld and good with metal fabrication you could make your own system, get valves and stuff from a scrap yard. Am thinking of doing it myself, with my own ecu and stuff. Just have to wait for the programming part of my degree. Quote
towe001 Posted August 2, 2010 Report Posted August 2, 2010 Talking about custom stuff and welding and all that crap. Been thinking of modifying an aisan "k" carb into something like this Injected carbies Either that or a set of quads or twins from a motorbike. And then its http://www.tweakit.net/shop/product_info.php?products_id=231 and weld four short sections of pipe to these http://www.tweakit.net/shop/product_info.p...products_id=138 for the motorbike throttlebodies Quote
snot35 Posted August 2, 2010 Report Posted August 2, 2010 Bugger the Aisin modification, get a throttle body from an EA falcon if you want bolt on injection. They use the Weber bolt pattern so your adapters will work too. Quote
jono1986 Posted August 2, 2010 Report Posted August 2, 2010 And then you need an ecu that's intended for the capacity of the motor, i think toyota starlet's are a small enough motor, thats the easiest and cheapest way. Quote
ke70dave Posted August 2, 2010 Report Posted August 2, 2010 jono1986 said: And then you need an ecu that's intended for the capacity of the motor, i think toyota starlet's are a small enough motor, thats the easiest and cheapest way. yeah but it will never run properly as its not designed to run on a k motor. just buy a megasquirt! 400 bucks for an ecu that has the same features as an ecu in the $1500+ price bracket. be prepared to read, alot. Quote
jono1986 Posted August 3, 2010 Report Posted August 3, 2010 (edited) Hmmm...didn't think you could get them that cheap. Even this if you know how to solder: http://cgi.ebay.com/ebaymotors/MegaSquirt-...sQ5fAccessories Or http://cgi.ebay.com/ebaymotors/MegaSquirt-...sQ5fAccessories Edited August 3, 2010 by jono1986 Quote
ke70dave Posted August 3, 2010 Report Posted August 3, 2010 unfortunately i can't get to those ebay links from work... http://www.diyautotune.com/catalog/megasqu...-kits-c-30.html but these guys are pretty decent prices 253US for the kit (277AUD) or 411US for one that is already assembled. (450AUD) Quote
jono1986 Posted August 3, 2010 Report Posted August 3, 2010 Plus postage, which on the ebay ones are $32.... Damn I wish I saw this kit at the start of the year. Quote
ke70dave Posted August 3, 2010 Report Posted August 3, 2010 and while your there pick up a wideband for $200 http://www.diyautotune.com/catalog/innovat...-3769-p-41.html and either find a laptop with a serial port, or get one of those serial-usb converters off ebay. and your set! it does turn into an expensive procedure though, but you are getting pretty good stuff. ~280 MS2, ~230 wideband, figure something out for the dizzy (unsure if the electronic k motor dizzy will work), youll need a few sensors (air temp, water temp). figure out what to do about a TPS. so not much change from say 700AUD. then whatever you need to get a k motor EFI intake manifold (either make one, or buy an expensive OEM one that fits). worth it on a stock 5k? i say hell no:P Quote
altezzaclub Posted August 3, 2010 Report Posted August 3, 2010 Does anyone know how Triumph 2.5Pi injectors worked? They were a simple mechanical system. Quote
