Gnaget Posted July 20, 2010 Report Posted July 20, 2010 Hello. Searched on the web but didn't find the answer so I ask here. I want to take a T50T tranny and put a T504A bellhousing on it so my KE11 tailshaft fits bolt on. Is there something I must change on the box or is it just to switch over and go ? Thanks Quote
mikey_m Posted July 27, 2010 Report Posted July 27, 2010 I have done the research and a mock bolt up and it seems to work. I have an AE71 and have this worked out so I can run a T Series T50 behind the 4A Swap Bellhousing and Rear Housing for the shifter (Same bolts and Gaskets) Then use a KE70 Tailshaft to matchup the new rear output shaft on the Tseries T50 Quote
tojo2 Posted July 29, 2010 Report Posted July 29, 2010 Gnaget said: Hello. Searched on the web but didn't find the answer so I ask here. I want to take a T50T tranny and put a T504A bellhousing on it so my KE11 tailshaft fits bolt on. Is there something I must change on the box or is it just to switch over and go ? Thanks Pre 82 T- t50 like you want to use got smaler input bearing so you need a spacer to center it in the 4A-t50 bell. Should find some info on it if you search as its been mentioned a few times :) Quote
AE25 Posted July 30, 2010 Report Posted July 30, 2010 tojo2 said: Pre 82 T- t50 like you want to use got smaler input bearing so you need a spacer to center it in the 4A-t50 bell. Should find some info on it if you search as its been mentioned a few times :) 2nd that. theres no difference between a late T series T50 (ta61, te71 1983+) and the 4age T50. they are both 22spline and interchange. any 20 spline t50 has a smaller input shaft bearing that locates on the bellhousing.. which requires a locating ring to keep the gearbox concentric with the crank. Quote
