ooohh.. tricky!
So you know there's raw petrol being pumped in there and it still can't go.
but i should be getting smoke out the tail pipe?
I'm not sure if its a fuel or ignition problem. i gotta swap the coil/ ballast over from my working 4k
  • 4 months later...
I'm having the excate came problems now, but I'm running a 32-36 weber.
what was it in the long run? i have a feeling its my fuel pump not filling the fuel bowl fast enough.
haha would really love this problem to go away, its annoying as shit when your car randomally loses power on a main road! hahaha
problem was the coil arking out on the negative post of the coil.
i stopped on the side of the road and i could hear it just zapping away. changed the coil and no problemo
Coil zapping away, sure you didnt flys or mozzies under the bonnet being zapped :laff:
