There are some radiator flushes out there, but I don't know how good they are.
I can't see them cleaning the rust out very well.
A bit of Google on the by-pass hose says it is to circulate water around the engine before the thermostat opens and to prevent cavitation in the pump. So its worth keeping it there if you can, but it won't be causing your overheating problem.
Have a chat to some radiator guys about it and see if they have any ideas we've missed.
  Quote
Overheating can be caused by anything that decreases the cooling system’s ability to absorb, transport and dissipate heat, such as a low coolant level, loss of coolant (through internal or external leaks), poor heat conductivity inside the engine because of accumulated deposits in the water jackets, a defective thermostat that doesn’t open, poor airflow through the radiator, a slipping fan clutch, an inoperative electric cooling fan, a collapsed lower radiator hose, an eroded or loose water pump impeller or even a defective radiator cap
http://www.arrowheadradiator.com/overheati...s_and_cures.htm
This is all based on the assumption that you got all the air out of the system when you changed engine.....
Park it facing uphill, rad cap off, heater on, fill with water, squeeze hoses while running, rev it up and down... Unlikely to be the problem but you never know.
i have done that except i havnt had the car on a hill. will give it a shot now and get back to you
Well I just jacked up the front of the car and started it with the cap off and there was abit of air but not much and yeah still the same problem. I can't seem to understand this o doubt it's rust blockage inside cause green coolant came out when I was putting it back in.
Well, its a puzzle!
Why did you change engines? Can you rebuild the old one to drop it back in?
Its a hell of a lot of work to strip the new engine to check if it is sludged up or not, I'd hate to do all that work and find out that the reason was something else.
Now you mention it, last year we had the rolla overheat going up to northern/inland NSW before I fitted the mods and cleaned out the rust, and there has been no sign of the temp hitting halfway since.
Might be because its winter! :)
Well I changed the motors cause my other one had done 700 000 km's lol. My new one is about 179000. do you know when the next cruise is in nsw? Wouldn't mind going if my cars going
  altezzaclub said:
Well, its a puzzle!
Might be because its winter! :laff:
even the local radiator specialist can't work it out lol. he told me to change my gauge and see if that helps. come to think of it i actually did change the whole dash cluster with the new motor because of the speedometer. i will give that a try ahah
