printed forms section Posted June 20, 2010 Report Posted June 20, 2010 Hi all, grabbed a 5 speed k50 from the wreckers, it's going into my rolla. this new box has signs of oil leaks, my 4 speed has none and i don't really want to start dropping oil everywhere... is there easy seals to replace on these boxes? and if so should i source from toyota or CBC bearings etc... i've had the bottom cover off and all looks quite good inside, i'll gasket goo the cover back on just wanted to know if there's a front or rear seal worth replacing and easily done without ripping the box apart? cheers Quote
rob83ke70 Posted June 20, 2010 Report Posted June 20, 2010 rear seal isn't that bad to do, I'd also pop the extension housing off and seal with a new gasket or silicone. front seal I don't think was that bad to do either. then there is just the plates with the detents, and the selector gasket, which shouldn't be hard either. put a new o ring on your speedo drive too while you are there. Robert. Quote
