Rolliac Posted June 13, 2010 Report Posted June 13, 2010 (edited) Got a 32/36 on a 3T-C and noticed that when the secondary throttle is opening (after half throttle) the secondary accelerator pump jet doesn’t squirt fuel. Primary pump jet is sweet. Seems to be a slight stumble between primary and secondary and thought this would be why. Got 50/60 idle jets which I think should be about right. So yeah is the secondary accelerator pump jet supposed to work on these things? Help appreciated. Edited June 13, 2010 by Rolliac Quote
Felix Posted June 13, 2010 Report Posted June 13, 2010 Nup. The accelerator pump only squirts into the primary throat on a DGV. If you had a 38/38 DGAS where both throttle plates open together, then the accelerator pump squirts into both throats. I'd check your secondary idle jet for blockages. Maybe try a larger one. Quote
Rolliac Posted June 13, 2010 Author Report Posted June 13, 2010 Felix said: Nup. The accelerator pump only squirts into the primary throat on a DGV. If you had a 38/38 DGAS where both throttle plates open together, then the accelerator pump squirts into both throats. I'd check your secondary idle jet for blockages. Maybe try a larger one. You da man. Thanks dude. Quote
