ninja-philbo Posted December 23, 2012 Report Posted December 23, 2012 the hks ssqv is a great bov had 3 of them Quote
Jaydnisevil Posted January 15, 2013 Author Report Posted January 15, 2013 (edited) Few bits and pieces done today, I've started putting thing's back together... Somewhat. I mentioned that the head was machined, but never showed any pictures for some reason. Warp in the head Machining As you can see, it was quite warped over 2 and 3, most likely why the gasket blew out from there :P Thermostat housing is back on with a new gasket, WD40'd parts of the head to prevent rust while I wait for my head-studs; taking their sweet ass time. Finished painting my manifold again, put a bead of petrol proof threebond on the rim of my carby bowl to stop the fuel weep under boost (Which caused the paint to lift last time) I'll order a new gasket tomorrow because the one that came with the kit was shit quality. I also still need to make up a new gasket for the external gate, as the old one blew out; the rest of the gaskets (Head, manifold, etc) I've got now. I'll post a picture of the JB welded manifold all painted up when I get home, I intentionality left the rear two legs at the bottom untouched as a comparison as you can't normally see them. It looks better than normal, it could have looked excellent if I spent more time on it. I just got lazy with the file and sandpaper :P Anywho, as you can see on the right I did not put any JB/Cold weld on it the lower legs. I'll get my replica BOV mount welded on this week hopefully. [insert picture here] Edited January 20, 2013 by Jaydnisevil Quote
Jaydnisevil Posted January 20, 2013 Author Report Posted January 20, 2013 (edited) I've gotten impatient with the head studs, so I'm slowly putting it back together and fixing a few things once the main parts are on. Somehow I've managed to misplace a head bolt (That was on my bedside table, but has somehow disappeared) Anywho, they aren't torqued down, so I'll just leave it on until I either find the bolt, or replace them with studs when they arrive. At least it's in a position that I can hook up most of the hoses and stuff again. Ohh yeah, my girlfriend made the heat-shield for me; another freeby from work :) Might neaten it up when I have some spare time. Edited January 20, 2013 by Jaydnisevil Quote
Jaydnisevil Posted January 22, 2013 Author Report Posted January 22, 2013 Manipulated the heat-shield into position Carburettor has a brand new genuine gasket, so shouldn't leak petrol this time -_- Blow off valve is welded on New Ignition coil, HT lead and dizzy cap (To ensure a good circuit and a good spark with the increased load on the system) In addition, tonight I connected back up a bunch of hoses, refitted the waste-gate with 2 gaskets and new nuts. I then went to work on how I planned to hook up my pressure regulator, bov and gauge separate from the waste-gate to ensure a good vacuum and boost supply. Kinda hard to do neatly, so I'm taking my time while I wait for the head studs or missing bolt to turn up. Quote
ro11in#22 Posted January 22, 2013 Report Posted January 22, 2013 hey mate where did you get them runners on your intake manifold and what size are they thanks Quote
rian Posted January 23, 2013 Report Posted January 23, 2013 ^Looks like steam pipe, you should be able to get them from any industrial store in different sizes and types of bends. I don't know why I haven't read this thread before? This thing is awesome! Quote
Jaydnisevil Posted January 23, 2013 Author Report Posted January 23, 2013 hey mate where did you get them runners on your intake manifold and what size are they thanks Hey, they're 1 1/4" mandrel bend mild steel pipes. I got them from Performance exhaust in ringwood :) Quote
Jaydnisevil Posted January 26, 2013 Author Report Posted January 26, 2013 (edited) FOUND THE MISSING HEAD BOLT!! In my sock drawer -_- lol. Anywho it's running and the BOV functions well :) Need to get a new O2 though, it's long gone :( After that I need to: check and correct my mixtures Possibly install a larger secondary acc pump nozel Check timing Plumb in external gate neatly Change exhaust possibly to a side pipe with a single larger muffler BUG BOMB THE SHIT OUT OF THE CAR, SO MANY SPIDERS :'( Set boost to 12-13psi (Manifold reading) Few ideas in the works after all that, but it's finally running again :D Edited January 26, 2013 by Jaydnisevil Quote
Jaydnisevil Posted January 28, 2013 Author Report Posted January 28, 2013 Ohh yea, I bought a 5 speed trans also :D So I'll pick it up toward the end of the week, and MAYBE have it fitted this weekend? lol. Quote
Jaydnisevil Posted January 30, 2013 Author Report Posted January 30, 2013 (edited) Boost is set to 11-12 MPSI, I'll leave it there until I get the mixtures right after I replace the O2 Ultimately I want 12-13MPSI, I will say that it's building boost up nice and quick :D Will take it for a drive tomorrow hopefully and work on the ignition advance again. Gearbox will be picked up on Friday, busy weekend though so may not happen. Edited January 30, 2013 by Jaydnisevil Quote
Jaydnisevil Posted February 2, 2013 Author Report Posted February 2, 2013 Now featuring 5 gears :) Drives well, like having that extra fun gear. Pretty sure my mixture woes are due to the air correctors, as it stutters up above 4000rpm; but not below (At 10psi [i dropped it for testing, it'll stay there for now]) Won't know 100% until I get my replacement O2 :) Quote
Taz_Rx Posted February 2, 2013 Report Posted February 2, 2013 Try closing the plug gap up slightly to get rid of the stutter. And I hope you're not still using bp5ey's Quote
Jaydnisevil Posted February 2, 2013 Author Report Posted February 2, 2013 (edited) Cheers, I'll give that a shot tomorrow :) Still leaning towards the air correctors though as the exhaust pops and makes a fuss, except if I keep pumping the pedal at the top end. Nahh I don't think so, i'll have to check.. Think I went to a colder plug when it was pinging to rule that out. Can't recall to be honest :/ What would you reccomend? Edited February 2, 2013 by Jaydnisevil Quote
Taz_Rx Posted February 3, 2013 Report Posted February 3, 2013 b7es. I've been running them successfully for around 5-6 years now. Have mates who also run the same plugs in vehicles such as turbo RB skylines, supercharged 202 and more so quite a versatile plug. You'll notice as soon as you take it out of the box the tip sits a lot lower which can help with boost effectively blowing the spark out. Gap tem to 0.8 and close it up a little if you think it needs more. It mine it feels like boost/mixtures etc are good but struggles to gain speed, mainly in upper 3rd/4th gears. FYI..... http://www.rollaclub.com/board/topic/64563-eoi-grouy-buy-copper-em30/ Quote
Jaydnisevil Posted February 19, 2013 Author Report Posted February 19, 2013 Head stud's arrived :) Also, a new O2 sensor Quote
