Carts Posted June 3, 2010 Report Posted June 3, 2010 does some one know if a 3sge beams with 6 speed fit in a ke25 corolla Quote
Taz_Rx Posted June 3, 2010 Report Posted June 3, 2010 Anythings possible with enough coin, knowhow, patience and sometimes stupidity. :abuse: Quote
parrot Posted June 3, 2010 Report Posted June 3, 2010 Well you could have a look at this for some ideas. http://www.rollaclub.com/board/index.php?showtopic=11909 Plus I think there is KE55 somewhere in the rides thread with a Beams engine. Quote
philthy30 Posted June 3, 2010 Report Posted June 3, 2010 does some one know if a 3sge beams with 6 speed fit in a ke25 corolla I'm just about finished my conversion in my KE30. I found that the 6 speed is an extremely long gearbox and the shifter would've been where my handbrake is so I'm using a W57 with a modified bellhousing. Have a look at the link below any other questions just ask away. Quote
Carts Posted June 4, 2010 Author Report Posted June 4, 2010 I'm just about finished my conversion in my KE30. I found that the 6 speed is an extremely long gearbox and the shifter would've been where my handbrake is so I'm using a W57 with a modified bellhousing. Have a look at the link below any other questions just ask away. Thanks this is a great help. I will have to do a measure up and i was thinking there are a lot of cars with remot shifters that may be worth looking at. Quote
philthy30 Posted June 4, 2010 Report Posted June 4, 2010 Thanks this is a great help. I will have to do a measure up and i was thinking there are a lot of cars with remot shifters that may be worth looking at. No problems. Yeah to be honest I never looked into moving the shifter but I am sure there is a way of doing it. I just figured that it was easier to fit the W57. The 6 speed would be nice tho. Quote
philthy30 Posted June 4, 2010 Report Posted June 4, 2010 okay so I thought I would do a wee bit of research. Apparently you can unbolt the shifter off the back of the 6 speed ( J160 or AZ6 ) and turn it around to the forward position which is 2 inches further forward. This is still possibly not quite enough to clear the handbrake though ? Apparently The AZ6 is fitted to the SXE10, the S15, the RX8 and the MX5 Miata. You learn something everyday aye ? The olds have an RX8 with the 6 speed, it has an extremely short shift from factory and it is a bloody nice box to drive with. Anyway I hope this helps. Phil. Quote
Carts Posted June 6, 2010 Author Report Posted June 6, 2010 okay so I thought I would do a wee bit of research. Apparently you can unbolt the shifter off the back of the 6 speed ( J160 or AZ6 ) and turn it around to the forward position which is 2 inches further forward. This is still possibly not quite enough to clear the handbrake though ? Apparently The AZ6 is fitted to the SXE10, the S15, the RX8 and the MX5 Miata. You learn something everyday aye ? The olds have an RX8 with the 6 speed, it has an extremely short shift from factory and it is a bloody nice box to drive with. Anyway I hope this helps. Phil. Think I will have a look at some remote shifter from other cars and vans to see what sort or clearance is required. Quote
