  • Replies 65
Do you unscrew the knob out of the handbrake lever. If you do, it will disapble the ratchet. Makes it a lot easier to use in an event .... :D
a locker, talent, fwd
When I was competing in Ballarat, it was generally accepted that fwd was approx. 3-5 seconds quicker per lap of the autocross track. The bastards don't have to lift off when thay start sliding :abuse:
my dad drives v8 supercars
I was going to make a comment about this bit but since the thread has finely moved on i'm not going to worry about it....
About the only way i could think of "beating" that '82 is grip, but to be able to make the same fast turns as what the '82 can do you'd have to have the tail slide out and then you'll be losing the grip which will slow you down.
unless you can pull some talent out of your
Yeah... ask your Dad, he seems to know how to do it!
The trouble is that you're just starting your racing career and it is all about experience, especially when the driver is doing the car setup/building as well.
Try different things on your gravel test track- brakes, suspensions, weights ... everything mentioned here. The more you do the more you learn.
locked i welded it up. rules are normal khanacross rules, anything goes anything to dramatic they make me a special different class. but if i keep it a chassis car I'm right. engine free but bigger it is i go up classes, gearbox,diff,suspension free and road tyres only.
Edited by mitch-12
Full stops, commas and general punctuation.
I have no idea of what you just said.
We do you the courtesy of replying legibly, please do us the courtesy of the same.
Edited by Redwarf
My opinion of that would be get the suspension sorted first and then maybe up the motor.
Its no good having a massive power house under the bonnet and not being able to fully utilize it at the ground.
In other words - big torque monster of a motor but its useless cause all it does is smoke up the tires cause they can't hook up to the road cause the anti-squat and roll steer hasn't been figured out.
Do you get axle tramp Mitch? Does the tail step out under brakes?
Battery in the boot?
Radiator?
Driver in the back seat?
Softer rear springs or harder, flatter or more curved?
You should compare notes with Rob, he does exactly the same events.
Edited by altezzaclub
Radiator?
Ok so
battery in stock position
i have a vk radiator in stock position
driver on normal position
stock rear springs
has hp developments front end work
