Mitch-12 Posted June 1, 2010 Report Posted June 1, 2010 Hey i have a ke70 with a 4 speed manual i use it for offroad khanacross events and was wondering do k40 gearboxs like flatshifting from 1st to 2nd i don't care if the gearbox only lasts one event i jus need a slight egde to come 1st instead of second all the time and i can't do anymore to my car within the rules.... so yeah jus wondering Quote
Grand Master of Awesome Posted June 1, 2010 Report Posted June 1, 2010 just don't use the clutch SMASH THOSE SYNCROS Quote
Mitch-12 Posted June 1, 2010 Author Report Posted June 1, 2010 i have a dogbox in my track car its a vs holden auscar i can rev match and stuff but what happens if you hold it flat and jus pull it into 2nd? Quote
Evan G Posted June 1, 2010 Report Posted June 1, 2010 wont select 2nd, you have to match road speed to engine speed then it will slip in. better off just side stepping/dropping the clutch Quote
Redwarf Posted June 1, 2010 Report Posted June 1, 2010 (edited) No. Change normally. It wont make you any faster, and the equipment will last longer. You sound like you're heading in the wrong direction. Smooth is what you need to be. Smooth is fast. Edited June 1, 2010 by Redwarf Quote
StasIII Posted June 1, 2010 Report Posted June 1, 2010 You can do it, its very possible but it does break boxes. I'm on my 3rd atm Quote
Mitch-12 Posted June 1, 2010 Author Report Posted June 1, 2010 Redwarf said: No. Change normally. It wont make you any faster, and the equipment will last longer. You sound like you're heading in the wrong direction. Smooth is what you need to be. Smooth is fast. it would flat change like a dogbox it would be faster but usually with a synchro box its faster with the clutch Quote
towe001 Posted June 1, 2010 Report Posted June 1, 2010 Can be done with pretty well much any g'box. But i'm with Redwarf - smooth is fast. Quote
wagn Posted June 1, 2010 Report Posted June 1, 2010 StasIII said: You can do it, its very possible but it does break boxes. I'm on my 3rd atm Yep i've broken 2 k40's Quote
Mitch-12 Posted June 1, 2010 Author Report Posted June 1, 2010 so do yous jus pull the stick no clutch without lifting the throttle and it goes in.. how many gearchanges do they last Quote
coln72 Posted June 1, 2010 Report Posted June 1, 2010 If you treat a box like that - not long Another for smooth changing. You may (most likely may not) save a pooftenth of a second flat shifting, but the shock loading is gonna break traction and kick you sideways costing you bulk time. As Red said, smooth = fast, and he is one to listen too. Buy the way, I only killed one K40 in over 10 years of motorsport - back into first gear at 50km/h took teeth of first gear. Quote
StasIII Posted June 1, 2010 Report Posted June 1, 2010 hold it flat through 1st to 2nd and pump the clutch while moving it into gear. don't hold off the accelrator. wagn- 2 k40s and 1 k50 sent to heaven Quote
Taz_Rx Posted June 2, 2010 Report Posted June 2, 2010 mitch-12 said: so do yous jus pull the stick no clutch without lifting the throttle and it goes in.. how many gearchanges do they last There's no way you'll get it out of first without lifting off the throttle or using the clutch. Getting it into the next gear isn't so much of a problem, its just getting it out of the gear the currently has load on it. I spent my last outing to the dragway flatshift all gear all day, But: 1, I have a K-T50, although this still isn't indestructable. 2, I was only doing to stop the boost dropping off so much in gear changes. In an NA car I would pay my gearbox some resepect and use both feet. :D Quote
cuzzo Posted June 2, 2010 Report Posted June 2, 2010 Taz_Rx said: In an NA car I would pay my gearbox some resepect and use both feet. ;) You'd walk??? :D Fifth or sixth, just the clutch. Quote
