Hey Guys many of you might have already seen this, but i thought I would post here as this is a Corolla based forum
The car as it stands now, should be painted by late this week early next, the car runs
T3 Suspension, coil over front and rear (available from Raceflo here in Aust now www.raceflo.com)
T3 Camber tops
T3 5 link rear
T3 Caster rods
30 Spline full spool Hilux rear
Willwood 325 x 32 mm rotors and 4 spot brakes up front
R33 GTR skyline rear 2 spot calipers and DBA cross drilled and slotted rotors on the rear
18x12 F18 Simmons with 295/30/18 rear wheels
17x9 F17 Simmons with 235/30/17 front wheels
Fully welded and cross braced 10 point roll cage
PWR Radiator
Hybrid Intercooler
ST205 GT4 3SGTE engine
Titanium Valves
Secret Custom Cams
Raceflo Inlet and Turbo Manifolds
LS1 Throttle body
Sard Fuel Rail
1250cc injectors
GT35R Turbo
Ross Racing Pistons
Eagle H rods
Cometic Head Gasket
Exedy Carbon Twinplate Clutch
W58 Gearbox
Microtech LT10 Computer and Dash
Perspex windows
Velo Seats
CBY Flares
...........and much more
I am hoping to have the car ready in the next 2 or three weeks, so hopefully it will be desimating a drift track near you soon.
Some pics to enjoy, and if you have any questions or need some advice please feel free to ask
Jon
www.raceflo.com
www.rotaflo.com.au
Damn! Sexy is written all over that engine bay!
And the internals... my goodness! Jam packed with serious fun! Pop tart style :dance: (If you never saw the commercial, you'll never understand that last comment! haha)
Welcome to Rollaclub too! :jamie:
Keep us posted on this beast!! :dance:
As a resident drift hang-shit-on-erer, it hurts me to admit that this is going to be a really nice bit of kit. :jamie:
As such, can I've a drive??
The only thing I can find wrong with it is that Wilwood only has one "l" in it. :dance:
Edited by Redwarf
Cheers guys, thanks for having me.
as far as the injectors go, i am still deciding if i will stay with the GT35R or go up to the GT42R so the take no prisoners approach was implemented, just in case.Picture%20003small.jpg
sorry the shot is a bit old, i will get some more up when it is painted
Jon
That's umm...
WOW.
I LIKE :jamie:
Aren't 3S engines quad throttle bodied? If so, why convert back to single throttle body?
That's really nice.
I like it :dance:
the rules (if i have them correct) in quensland are that as long as the wheels are covered, as in there tyre does not protrude from the body, then it is legal (with the gaurds being part of the body). you would attract alot of attention with that colour though so i wouldnt count on it, the cops would do you for something..because they can.
also the GT42R turbo's specs may be misleading, 1000hp is the figure that it is capable of flowing (its usually give or take about 100-150hp of that figure), so it doesnt nessesarily mean when you bolt it on it will give you 1000hp, although it would be handy.
having said that I'm not aware of any 3s's that have gotten that sort of figure? (maybe i need to get out more?) i suppose it possible though.
Cheers guys
thanks for your input Nick, it certainly sounds like you know your stuff, so far I am in agreement with every thing you have said, so it saves me posting, cheers for that.
The only thing I will add with regars to the wheels is that the maximum size allowed under Australian Design Regulation is 10" and the rears are 12" and as such would not be passed in any state.
As soon as I can find a spare ST205 engine it will be dismantled and the head will be sent off to be ported, Bench flowed and tested, titanium valves fitted amd match ported, so we can chase every last HP in the engine.
It is very nice, isn't it? What hubs are you running (to get the 5 stud)? You mentioned custom coilvers from T3, what are these modified from? Standard AE86 struts? Did you find the metal heat shield over the radiator to help much with cooling?
I think there were some previous discussions about having *too much* braking power in a non-ABS equipped car.
Meh, I stand by my "never too much braking power" philosophy.
As for bias, the only way to test this would be to drive the car, and adjust accordingly. My car is very slightly biased toward the rear, but not enough for me to justify getting a bias valve at the moment. It only becomes a slight problem when I jump on the brakes hard, if I brush-and-bury (which is what you're meant to do anyway) it's fine.
