SLOTH Snr Posted August 9, 2005 Report Posted August 9, 2005 We have yet another problem since putting in the 7k. once the motor seems to have warmed every time you start getting past half throttle its like someones pulled the choke out. Ease up and it runs like shit till it's burnt off the extra fuel. A guy at motor improvments said he had the same problem and just put larger points. Has anyone else come across this before :jamie: Quote
Raven Posted August 9, 2005 Report Posted August 9, 2005 float level, make sure the jets arent too big, make sure its gota return fuel line or it'll flood the inlet with fuel. Quote
Ratty Posted August 9, 2005 Report Posted August 9, 2005 Get yourself a su carb and a manifold to suit your engine shoulnt cost much just hunt around, throw your other carby in the shed :sad: Quote
Teddy Posted August 9, 2005 Report Posted August 9, 2005 Give me the 7k and all relating. Exchange for 4k. Problem Solvered. :jamie: Quote
Super Jamie Posted August 9, 2005 Report Posted August 9, 2005 Get yourself a su carb and a manifold to suit your engine shoulnt cost much just hunt around, throw your other carby in the shed :sad: i like this suggestion. but two SUs Quote
dingo ke55 5k Posted August 9, 2005 Report Posted August 9, 2005 Throw your old carby away along with the SUs and get yourself a 32-36 weber off a Escort / Cortina. A 7K should have no problems with this carb :jamie: Quote
kangaroosa Posted August 9, 2005 Report Posted August 9, 2005 Throw your old carby away along with the SUs and get yourself a 32-36 weber off a Escort / Cortina. A 7K should have no problems with this carb :jamie: Pfft - I had a 32/36 on my 5k and it went alright. I now have twin SU's and wheeeeeee. I'm sure Jamie will agree. P.S. He's already placed an order for all the bits and pieces to setup his twin SU's. Quote
dingo ke55 5k Posted August 9, 2005 Report Posted August 9, 2005 The SUs are better? Better hook myself up then :jamie: Quote
Ratty Posted August 9, 2005 Report Posted August 9, 2005 Get yourself a su carb and a manifold to suit your engine shoulnt cost much just hunt around, throw your other carby in the shed :sad: i like this suggestion. but two SUs Yes good point ithink these are off a datto 1600? Quote
kangaroosa Posted August 9, 2005 Report Posted August 9, 2005 (edited) Here's Mine. :jamie: Edited August 9, 2005 by kangaroosa Quote
Ratty Posted August 9, 2005 Report Posted August 9, 2005 Nice and clean mmmmm twins u lucky bugger what motor do u have kanga Quote
kangaroosa Posted August 9, 2005 Report Posted August 9, 2005 Nice and clean mmmmm twins u lucky bugger what motor do u have kanga Worked 5K. Did anyone figure out what was wrong with Sloths carby? It used to work when the engine was first put into the car, right? Quote
Super Jamie Posted August 9, 2005 Report Posted August 9, 2005 read his signature :jamie: and while we're all having the "SU club" showday, here's mine :dance: Quote
SLOTH Snr Posted August 10, 2005 Author Report Posted August 10, 2005 Thanks guys. I have a set of su's from a triumph i'm about to fit up. Didn't want to fit them until i had some idea of a cure and it sounds like they might be it. Buy the way did i tell you Dazza Bush (kangaroosas) is a legend. The list of parts and suppliers he gave me for the su"s is brilliant. The photos leave no doubt as were things go. Hope to have the carbs fitted by sloth's twentieth. Will let all know how it goes. Quote
