skidrat Posted May 15, 2010 Report Posted May 15, 2010 hey there guys this might sound stupid but i have a ke70 panno that has a 4K with a cam, shaved head, twin solex's, and extractors. the problem is i keep killing standard fuel pumps. i am now thinking that standard pumps might not be good enough to do the job(or they could just be crap pumps). would anyone know if A. they are to small? B. what would be a good and fairly cheap setup i could use to get the job done if i need to go bigger. cheers sam Quote
Evan G Posted May 15, 2010 Report Posted May 15, 2010 skidrat said: hey there guys this might sound stupid but i have a ke70 panno that has a 4K with a cam, shaved head, twin solex's, and extractors. the problem is i keep killing standard fuel pumps. i am now thinking that standard pumps might not be good enough to do the job(or they could just be crap pumps). would anyone know if A. they are to small? B. what would be a good and fairly cheap setup i could use to get the job done if i need to go bigger. cheers sam are you using the 10mm spacer between the fuel pump and engine block? Quote
skidrat Posted May 15, 2010 Author Report Posted May 15, 2010 spacer? nope i have not heard of this being done Quote
Evan G Posted May 15, 2010 Report Posted May 15, 2010 you don't PUT a spacer in, from factory they should have a 10mm spacer there. grab a light and go double check. if its just fuel pump then block then thats the reason you keep shitting fuel pumps Quote
skidrat Posted May 15, 2010 Author Report Posted May 15, 2010 ahh ok the car is currently at my work(where i towed it after it shat itself) but i will have a look on monday. thanks for the help man this motor had just a plate blocking it off when i got the motor because it was running an electric pump before. so i doubt i would have put a spacer back in there when i put the mechanical one back in. thanks again sam Quote
Evan G Posted May 15, 2010 Report Posted May 15, 2010 no problem, ill get you a picture tomorrow (its to f@$king cold now lol) Quote
philbey Posted May 15, 2010 Report Posted May 15, 2010 My money's on the lack of spacer too, first thought as soon as I read the heading. It'll just tear the diaphragm apart without it. Quote
Evan G Posted May 17, 2010 Report Posted May 17, 2010 (edited) parrot said: Nice one Evan G! Good pickup. gone from a noob to a helper... Edited May 17, 2010 by Evan G Quote
skidrat Posted May 17, 2010 Author Report Posted May 17, 2010 yeah thanks Evan much appreciated i fixed it today got a new spacer from repco i think 6 bucks in total put another pump i had lying around home on and she runs sweet. it actually wasn't just the diaphragm the actual arm that goes into the block had snapped of and when it was recovered (from the bottom of the sump) it had about three separate area's where there where cracks in it. so thanks heaps for your help because i would have never figured that out without getting another car right next to mine. thanks Sam Quote
Evan G Posted May 17, 2010 Report Posted May 17, 2010 WOW! it snapped the arm in 3 peices :P first time ive heard about that Quote
skidrat Posted May 17, 2010 Author Report Posted May 17, 2010 well it only actually snapped in one spot but there where cracks in about three different spots along the arm that would have gone through pretty soon. not bad for just sitting on 60 in 4th Quote
