since no one makes 22mm ke55 sway bar D bushes i had to buy universal brackets and bushes
universal "D" bushes 22mm to suit late ke55 front sway bar - pedders EPB22 (ask for the brackets aswell)
ke55 rear sway bar lower link bushes - Pedders P280
ke30/55 front sway bar links - nolathane P/N 42080
mods add into FAQ?
i hope this information helps
Edited by Evan G
i called pedders in hornsby (sydney) and they had them in stock and had two sets on order. try calling them. might not be in the books.
ps that was yesterday.
thanks for the info fletch, are they the ones I'm looking for? rear lower link bushes?
yeah mate there the ones. i got prices for the whole rear set. upper lower and d rubbers. they had them all.
legend! thanks a million pal! ;)
pedders should be able to fix you up with something, they got some for me.
rear swaybar for ke55 is aftersales or aftermarket option, not factory. It looks factory, but thats cause its a good job!
Robert.
i went down pedders a couple of weeks ago with the old bush and they said they had nothing that small, i just rang the pedders in hornsby and they said they could match something up/????
Try superpro bushes
http://www.fulcrumsuspensions.com.au/superpro.html
interestingly, the whiteline sway bar i got for the front of my 55 is thinner diameter than standard, but does a much better job and comes with bushes to suit.
the bloke at pedders said they can get me 19mm front sway bar but mines 22 standard?
ill have a look through the superpro catalouge...
Yea, Pedders will be able to sort you out with the bushes to suit.
I've got a 22mm in the KE38. All bushes were from Pedders.
ive got the front all sorted but not the rear,
Ahk, No love from pedders?
well last time i went there i took the old bush with me and i asked the bloke if he could match something up and he just kept repeating "nothing that small". so i left disapointed
