chamb43 Posted May 4, 2010 Report Posted May 4, 2010 any ideas on what ebgine i can put in my ke70... herd 4age's are easy, how easy? cost? cheers. Quote
Sam_Q Posted May 4, 2010 Report Posted May 4, 2010 (edited) there are many many tech threads on it if you do a search, also check the FAQ section. Ah also have a look an ae86dc, but search only I have some articles on my site that might help you later: http://s-86.com/articles.html Edited May 4, 2010 by Sam_Q Quote
swarf. Posted May 5, 2010 Report Posted May 5, 2010 (edited) rough estimate from what i've researched 4age - $800 (varies depending on what comes with it) T50 - $300 AE71 crossmember - no more than $100 (shouldn't be at least) tailshaft from AE71 - no more than $150 then you will have to think about diff upgrades, brake and suspension upgrades, fuel systems, tuning, wiring, labour. etc etc etc hope this helped, and good luck with the project :bash: edit - also, correct me if i'm wrong, but that looks to me like an ae71 wagon? high roof, slanty front. double check, if it is an ae71 wagon, the conversion will be a lot easier ! Edited May 5, 2010 by swarf. Quote
Ben-89 Posted May 5, 2010 Report Posted May 5, 2010 Thats a late model ke70 wagon, hence the slanty front. Also has the hi cam badge. Quote
chamb43 Posted May 5, 2010 Author Report Posted May 5, 2010 Sam_Q said: expensive pedal box too how much would a 13b or 12a conversion cost? Quote
Sam_Q Posted May 12, 2010 Report Posted May 12, 2010 sorry I can't answer that one it would depend on too many factors Quote
