skizzamods Posted April 25, 2010 Report Posted April 25, 2010 Hey, just need some help in regards to replacing the radiator support. Mines suffered from some damage and can't be bent back. Is it just a series of spot welds I need to drill out to remove it? Or what is the best way to do this? cheers Quote
Taz_Rx Posted April 27, 2010 Report Posted April 27, 2010 Yes just drill out the spot weld to remove it. Then re-weld or put some bolts through the holes you drilled if you want to be able to take it off again to make engine removal easier. Quote
