Hey,
just need some help in regards to replacing the radiator support. Mines suffered from some damage and can't be bent back.
Is it just a series of spot welds I need to drill out to remove it? Or what is the best way to do this?
cheers
Yes just drill out the spot weld to remove it. Then re-weld or put some bolts through the holes you drilled if you want to be able to take it off again to make engine removal easier.
