sounds like you got some work ahead of ya keep at it an will be watching this thread very closely seening how you and me a just a few people building them up tho mine will look awsome but be stock motor pretty much untill i decide to something with a turbo lol
yep sure do have some work ahead, its complete bare shell lol, ive been keeping a close eye on yours for the same reason see if i can pic up any little tricks that youve tried etc my motor will be just a 13t with extractors and single weber nothing special until i find a suitable replacement, I'm hoping mine will turn out alright clean streeter.
ill get some pics up tonight.... hopefully
  • Replies 111
hey bud any further progress mate
hey mate yeah done some more 80% of engine bay is now bare metal, started degreasing underneath so i can grind that
and ive now got a RN25 Hilux diff lined up from a mate so things are slowly coming together.
and I'm going to use a camry brake master cylinder from a 03-06 camry
heres some photos ill get some more work done on it tonight
enjoy let me know ya thoughts :(
made a little list to get it on its wheels
Underneath
Finish drop box welding
Grind Welds flush on drop box
Wire Brush Underneath, front to rear
Knock out any dents
Fix shifter hole
Weld any holes
Grind any welds
Por15 underneath rust protector and sound deadener.
Inner Front Guards
Wire brush inner guards
Replace Inner L wheel arch
Weld up
Grind
Weld up holes inner guards
Grind up holes inner guards
Replace front quarter panel bolts bottom
Straighten up front panel
Por15 rust protector and sound deadener inner guards
Front Quarter Panels
Wire brush inner front quarter panels
Differential
Grind and Por15 diff (either RN25, T Series)
Struts
TA22, or AE86
Grind
Powder Coat
Steering Rack, Cross member, LCAs & Mounts
Grind
Powder Coat or paint
Brakes
Grind callipers (TA22 or AE86)
New rotors (TA22 or AE86)
New brake pads (TA22 or AE86)
Order Suspension Parts
Order 7-8kg front springs and rear springs (AJPS, Kingsprings, Pedders)
Order suitable shocks for front and rear (KYB/AGX, Koni
Order front swaybar (24mm or similar)
Order front swaybar bushes (if not in swaybar kit)
Order all new front end bushes (pedders or Nolthane)
Order rear Panhard rod (AJPS or Whiteline)
Order rear bushes
Order strut brace (AJPS, CUSCO, Whiteline)
Camber tops?? (AJPS, CUSCO)
Brake Lines
Order new Brake lines
Rear Brakes
New drum shoes or rotors
New drum cylinders or pads
Installation of Bushes, Swaybars and Springs
Install all new bushes, shocks, springs
Engine Bay
Grind
Fix rust
Seam weld
Grind welds
Smooth
Putty Primer
Paint Voodoo Blue
Install Front End
Attach Cross member
Attach LCAs
Install AE86 or TA22 shocks, springs, tops, rotors, hubs.
Attach new brake lines
Attach callipers to rotors
Install Front Swaybar
Install Tension Rods
Install Steering Rack
Install Back End
Install Diff
Install 4 link
Install shocks
Install springs
Install Panhard rod
Wheels
15” Sigma Turbo Wheels.
14” Chaser Stockies
13” Jelly Bean Mags
14” or 15” White Wall tyres
14” Chrome wheel trims and centre caps
Anodised Blue Wheel Nuts.
Interior
Grind, sand interior
Seam weld
Cut out and replace rust sections
Por15 rust protect interior
Dynamat interior
Reinstall handbrake.
Connect up handbrake
Replace Rear Seat Anchors
Rear Quarter Panels / Boot
Fix rust rear panels
Grind boot
Por15 rust protect
Dynamat soundproof
Replace rear parcel shelf
Boot and Fuel Tank Setup
Paint fuel tank
Surge tank and fuel pump set up
Make sealed box for both
Mount battery box
Run battery cables
Carpet / Trim boot black carpet
still truckloads to go haha
Edited by MattyZ
just tossing up which rims i want to run later on down the track ive narrowed it down to 3.... for now haha
Work Kai polished or white
Work Equip 03s polished
SSR Professor SP1 R Polished or silver
Opinions needed personally I'm either leaning towards the Equip 03s or the SSRs more the Equips either one will have mad dish haha
ok so 99% of this has been about my celica and not about my corolla so ill give you a bit more of an idea on what i have planned for it
I will be keeping the body how it is just tidy it up, eg. repair the rust around the boot seal and inside the boot the only exterior change i will make is add a pair of chrome rectangle mirrors to the doors and order a white interior venetian blind
rolling i might invest in a set of challengers or just run 14inch stock wheels with low profile tyres white walls
engine wise, i will either go with a warm 5k duel carbs extractors pistons
or a 5kze or te undecided yet.
upgrade all the suspension brakes etc AE86 items but over all keep it sleeper but that might be hard with yellow in ya face paint, if it comes to it and its covered in primer patches ill respray it devil yellow and re apply the black pinstripe
please let me know your thoughts and ideas on this
ok so today ive started to replace the left inner wheel arch, i started by removing the inner arch from my donor celica
and cutting away the fat till i was left with what i needed shown below
then i cut away the corner which the quarter panel bolts to at the bottom heres the rusted and the repair piece and repair piece held in place
heres the nice tiny size hole left in the floor pan and inner gaurd
i also have to replace the backing for the corner piece which was not rusted in the repair piece so i just cut it all out into one big section
hopefully by the weekend i can have it all tacked up or fully welded in so i can rust prevent it and then wack some Por15 and sound deadner on the interior and exterior of it
enjoy
so i got it relatively lined up few gaps but nothing that can't be filled, with a sliver of metal.
got it tacked now just need to finish the taking then go round till no more gaps
use a linishing disk to grind the welds flush, wire wheel brush surrounding area and rest of inner guard and move onto replacing the metal section where the battery tray used to reside.
ok got the left inner guard all bare metal now, and the replacement patch it all in and welded up just need to grind welds flush and then i can start to replace the section where the battery tray is, once that is done the inner guard will be ready for a coat of rust preventative paint and then a coat of black sound deadner.
ill get some pictures up today once ive done some more work slowly coming along nicely, I'm going to need to do a run to AJPS and get new clutch cylinder, rear sway bar, some springs and shocks for the front end. drop into autopro and order a 03-06 camry brake master cylinder.
so here's the pictures, grinded the arch to bare metal, and did finished doing the last bit of welding on the replacement section now i just need to grind it all relatively flush and bobs ya uncle finished that was gonna be one of the hardest part of this rebuild, the next hardest part will be to replace the parcel shelf and window seat or frame what ever ya wish to call it.
Sad part is that altho' excellent work, would've been soooo much easier with a better shell
But you get what you get so, ++++ points for the effort !
yeah my donor had lest rust but it was in harder place to repair like numerous holes in the roof skin so I'm just gonna use the good parts from my donor
wheres the fun if its easy hahaha.
got quite a bit more done, seam welded quite a bit of the front end, just need to do underneath, left passenger side is all baremetal inside, and the inner guard is all welded up.
started to wire brush the light assembly get it ready for a coat of gloss black, since the headlights produce some heat, should i use heat paint for the long term or just go with rattle can gloss black?
before
after
