this thing is gonna scare me! going from a torquey 4k with a redline of 5000rpm to lumpy slut with a power band of 3-7 :D
i can't wait to get this done but at the same time I'm not gonna rush anything. everything needs to be 110%.
cam in. timed to perfection with a dial indicator.
all thats left.
  • thermo housing
  • drill new hole in 4th runner for booster
  • fit new manifold
  • change oil and run in new cam
  • recheck valve adjustment
  • time the dizzy
  • SCARE SOME BOGANS!
cam timing is 110%. next thing after this is getting the carby looked at. i think its the power valve always stuck open therefore ZERO fuel eco.
http://www.youtube.com/watch?v=8lBlDcN7fCs
all finished! i need to tune the carby badly. loves it up to 7 grand :D
if I'm idling for a bit theres no vacuum in the booster? i thought the valve adjustment was a little tight so i re checked that. when taking off it just doesnt move untill 3 grand then all hell brakes loose :D
needs rejetting and another hotbox gasket as the bolts ratlled them selves loose :glare: Edited by Evan G
You need those little spikey washers. They bur in and should stop them nuts coming loose.
Edited by GJM85
