GA galant. it's dual circuit too, so you'll need to get new brake lines made up in the engine bay
later model GD galant is a larger bore, say if you fit bigger calipers
Yep goes straight in ive got one in my ke20. Just make sure you pull the master cylinder down and clean it and hone the bore just to be certain. You can never be too careful with brakes.
