Des Posted April 3, 2010 Report Posted April 3, 2010 Hey Hey, I've seen a few different designs of intake manifolds for Carby fed 4AG's. I'm curious to see what people have done with theirs in an AE71/KE70/AE86. The main bits I'm after are manifold length, Carby positions, Linkage setups, Fuel line setups, Fuel pump setups and air filter setups. Parts list so far that i think i will need: 40mm Webers x2. I have Linkages. I have Carter 4070 or Holley red fuel pump. Intake manifold to suit small port 4AG. Fuel regulator set at 3.5 - 4.0 psi. Trumpets. Air filters/Air box. Have i missed anything ? Des :D Quote
bLinded_ Posted April 3, 2010 Report Posted April 3, 2010 (edited) Soft mounts for carbs? Studs/nylock nuts to mount carbs to manifold? Edited April 3, 2010 by bLinded_ Quote
Des Posted April 3, 2010 Author Report Posted April 3, 2010 Soft mounts for carbs?Studs/nylock nuts to mount carbs to manifold? Yes those too. Do you have more pictures of your K motor setup ? Quote
bLinded_ Posted April 3, 2010 Report Posted April 3, 2010 Sorry don't have many photos of my setup, but if you want, tomorrow I can get a couple more or a short video if you are after something specific. :D That is about the only one I have. Just let me know if you want more. Quote
twisted2 Posted April 3, 2010 Report Posted April 3, 2010 hey mate heres what ill be running one day soon i hope a redline mainfold to suit 4age but bigport Quote
Des Posted April 3, 2010 Author Report Posted April 3, 2010 Sorry don't have many photos of my setup, but if you want, tomorrow I can get a couple more or a short video if you are after something specific. :D That is about the only one I have. Just let me know if you want more. The more the better mate, What fuel pump are you using ? hey mate here's what ill be running one day soon i hope a red line manifold to suit 4age but big port What are they worth, I found them on the red line site but didn't see any prices anywhere ? Quote
Trev Posted April 3, 2010 Report Posted April 3, 2010 Des I hope your going to use a regulator with the holley red. Quote
Des Posted April 4, 2010 Author Report Posted April 4, 2010 Des I hope your going to use a regulator with the holley red. Yesm. Post some pictures of your setup Trev. Quote
Trev Posted April 4, 2010 Report Posted April 4, 2010 As you know it is not mine anymore (hopefully the new owner makes a rides thread since its mobile): 45mm dcoe's. Fedtro 5-7psi inline pump. Hyperpak ignition. Des the guy that now owns my old AE71 lives behine RACQ where you were, I wanna go check it out soon, Let me know if you wanna come have a look. Quote
Des Posted April 4, 2010 Author Report Posted April 4, 2010 Yeah i will go with you. Is that the red line manifold ? Quote
Trev Posted April 4, 2010 Report Posted April 4, 2010 Nah I don't know who makes them, Look on ebay US for them. Quote
corollaart Posted April 4, 2010 Report Posted April 4, 2010 Can buy them from hardimans auto supplies sydney. www.redlineauto.com.au. Big port or smallport ,bigport part no 12-23 ,$222.54 +frieght. cheers rob Quote
bLinded_ Posted April 4, 2010 Report Posted April 4, 2010 Des, with the setup I run, I am still just using the standard mechanical fuel pump. Also not using a regulator, but I am yet to have any problems at all from too much/little pressure. Didn't get to take any photos today as I was busy, but can do tomorrow. Quote
Trev Posted April 4, 2010 Report Posted April 4, 2010 (edited) Des, with the setup I run, I am still just using the standard mechanical fuel pump. Also not using a regulator, but I am yet to have any problems at all from too much/little pressure. Didn't get to take any photos today as I was busy, but can do tomorrow. 4ag does not have a mechanical pump tho, Last time I looked at a holley red they were around the 12psi mark, Just checked again and they run a max of 7psi Dunno if they have changed the pumps at all as the blue one looks lower. Des If the reds only push 7psi max then don't worry bout a reg. EDIT: Forgot to add that the recommended PSI for a weber is 4-5psi. Edited April 4, 2010 by Trev Quote
bLinded_ Posted April 4, 2010 Report Posted April 4, 2010 Yeah 4AG will have a normal EFI setup with high pressure pump, but I was just answering Des' question about what I use. :blush: I think even though 4-5 PSI is recommended for Webers, I think providing that the Needle and Seats are in good condition, a bit of excess pressure should still be fine. Might be a matter of seeing how 7PSI goes, and slot a regulator in if need be. Quote
