asif Posted April 9, 2010 Author Report Posted April 9, 2010 i thank you all for taking time to add comments here :( about its history, the car is with us since august 1986. previously it was owned by a military officer (our acquaintance) & he did approx 68000 km on it & kept it good. back in 1994 i changed the head-gasket because the coolant started to disappear. later changed the radiator too. i could not find genuine ke30 radiator so i purchased a genuine ke70 radiator, got side brackets of ke30 soldered on it & installed the same. so you can see the radiator cap is at one side & the upper-hose is like a question mark (not L-shaped). rear-view mirrors on fenders are not stock. replaced the regular nippondenso high tension ignition coil with a denso gt-coil about fifteen years back. recently i replaced set of high tension ignition leads since previous ones aged too much, this too with genuine toyota part. also fixed a third brake-light on rear deck which i manged from an auto junk-yard. i think the black spray paint from tin canister on differential is making it suspicious :) asif Quote
