Alec here again with the Ke70 (4k) with a stock diff.
I've got some gearbox oil here that says i can put it in my diff? might be a silly question but can i do that?
also do i have to take the back plate off the diff to drain the oil? and if so do i need another gasket or something to replace it with?
cheers guys
Alec
Yeah you'll have to take it off and you'll probably need to replace the gasket which probably is a good idea anyway. Though I've just loosened the bolts and pried the bottom open a bit and drained it that way.
80w/90 is the diff oil recomended in the manual.
EDIT: I say it to everyone, a gregorys manual is worth its weight in Rolla's.
Edited by blzbub666
cheers bro, i'll have a look at how bad the gasket is, might top her up for the time being. time to find a 28mm spanner.
yeah i got a Haynes, its shit.
gotta pick up a gregories one of these days.
thanks man
