Felix Posted August 16, 2005 Report Posted August 16, 2005 so long as you have the jap diff housing.. yes Quote
Super Jamie Posted August 16, 2005 Report Posted August 16, 2005 yes, there are no differences in splines or carriers across japanese frontloader-style U series diff centers the early ke1/2 ones have a different pinion flange, but you can just change the tailshaft end at the uni. if you're pulling the diff center apart, there are two or three different styles of pinion bearing if you have an australian ke70 with a borg warner U or S series diff, identifiable by the bolt plate on the back, then you're out of luck Quote
styler Posted August 16, 2005 Author Report Posted August 16, 2005 well considered the locker (welded) but didnt choose it due to legality and driveline stress from everyday driving. lockers would be stronger than the original diff because the pinion gears and side gears are welded together as a unit which leaves only the input pinion and ring gear operating which is a strong setup. then the axels start breaking lol. Quote
Ratty Posted August 16, 2005 Report Posted August 16, 2005 Hey Fook what diff set up are you running in your ke35 beast ? Quote
demuire Posted August 16, 2005 Report Posted August 16, 2005 RA23 diff, Cusco LSD, Bluebird TRX disc brakes. Quote
Ratty Posted August 16, 2005 Report Posted August 16, 2005 sweet that sounds like you have a good diff assembly and rear disks nice :D ive been looking at a diff out of an M3 with disks and lsd but its $$$$$$$$$$$$$ Quote
Super Jamie Posted August 16, 2005 Report Posted August 16, 2005 i generally would stay away from anything european, unless you have a severe need to waste money paying premium price for fairly ordinary parts every m3 has also been irs, so it's hardly going to be a bolt in job. check the recent toyota irs conversion someone did to a celica on toymods, fook posted it on here somewhere Quote
Toycrash Posted August 17, 2005 Report Posted August 17, 2005 a day at a few different wreckers and not too much luck... was looking for a ke25 sized diff, which is 1320mm mounting face to mounting face corona mkII - too wide 14??mm r31 skyline - too wide 14??mm hiace - too wide 13??mm L300 - too wide 14??mm chrysler lancer - 1320mm! 120y - couldnt find one but is meant to be close 13???? commodore - too wide datsuns - some possibilities, will check out a few soon escort - 1340mm, little bit too wide ke30 - 1370mm, too wide ta22 - 1370mm, too wide volvo - too wide scorpion - too wide hilux old - 1370mm, too wide some vans - 1370, 1370+ too wide so not too many cars that would have suitable width diffs :sad: oh well looks like a shortening job then$$$ How about lite-ace or town-ace? 7" and think it takes hilux front axle lsd. Quote
rob1 Posted August 17, 2005 Report Posted August 17, 2005 Tell me more!!!! So a town ace diff..................convert it to leaf mount..............then wack in a hilux front lsd centre??????? Town ace diff shouldn't be hard to pick up nor dear Quote
suri123 Posted April 17, 2017 Report Posted April 17, 2017 hi i just put mitsubishi express diff and cressida front arm with sturt and bakes disc all together look nice wheels sticking out flush with gaurds on ke 30 1978 Quote
