original Posted March 14, 2010 Report Posted March 14, 2010 just eliminating a few things while trying to get my car started. Does the standard gze ecu prime the fuel pump when the key is in the "on" position? or is that an after market thing? Cheers, Quote
Medicine_Man Posted March 14, 2010 Report Posted March 14, 2010 it will prime it during crank and then keep the pump powered via the circuit opening relay when the car is started. Quote
original Posted March 14, 2010 Author Report Posted March 14, 2010 cheers, ill add that to the list of things todo tomorrow Quote
original Posted March 15, 2010 Author Report Posted March 15, 2010 ok, so no prime on cranking. getting no voltage reading across the fuel pump. what else can I check? Quote
Kebin[RL] Posted March 15, 2010 Report Posted March 15, 2010 it all depends on how your car has been wired. is there a circuit opening relay in the car? if not, a fuel pump relay? Quote
original Posted March 15, 2010 Author Report Posted March 15, 2010 yes there is a circuit opening relay, diagram says there is a fuel pump relay, but its a conversion so can't be sure Quote
original Posted March 16, 2010 Author Report Posted March 16, 2010 (edited) This is how the relays map out and how i believe they connect based on the club4ag wiring diagram, my engine bay and its colours. gotta get a multi meter with buzzer so i can check a couple more things. is this what it should look like? Edited March 16, 2010 by original Quote
Kebin[RL] Posted March 16, 2010 Report Posted March 16, 2010 Who wired up your car? that diagram is crazy... and mostly wrong. What is relay #2 for? What triggers your thermofan relay? If you wire it as per the factory ae101 4agze wiring diagram then it will run fine. Quote
original Posted March 16, 2010 Author Report Posted March 16, 2010 (edited) Kebin said: Who wired up your car? that diagram is crazy... and mostly wrong. What is relay #2 for? What triggers your thermofan relay?If you wire it as per the factory ae101 4agze wiring diagram then it will run fine. believe it or not it was an auto sparky :wub: as per this diagram where to 10A Ignition and 15A Efi go? Edited March 16, 2010 by original Quote
original Posted March 17, 2010 Author Report Posted March 17, 2010 so, so, so angry right now.... turns out some f@$king iron dust got in under the Circuit Opening Relay and was holding the switch open and because its magnetised, it would not move :wub: cheers kebin and medicine_man for your help. now to finish my diagrams and understand this mess :D Quote
