Hey guys, currently trying to get the tailshaft off my ke55 and the bolts are on really fkn tight. Ive WD40d them and they still don't wanna budge. Ive got limited tools and have been using a 12mm spanner but I'm unsure if this is the bolt size (seems to be a tiiiny bit of play) Anyone got any tips to help get the thing off?
Yeah ive only got a shitty spanner set at the moment and have already slightly rounded one so thought id come on here and ask. Can anyone confirm what size the bolts are?
put spanner on bolt and use ya jack to turn it and use the weight of the car to crack it. If you have shit spanners don't try this. I did this when had no room for a strong arm. Worked sweet.
For whatever reason I always use vice grips to hold the side which is harder to get a spanner over. Then use a socket and breaker bar on the other side. I just tried it one time due to limited tools and it works a treat
Hasn't failed me yet and no rounded bolts either... If you jam the vice grips up against the car it will also have the added bonus of holding it from spinning while you crack the bolt :P
