As the title says seems like the alternator is putting a signal through my speakers when I give it gas the signal gets louder and louder. I have disconected the alternator while the Car is going and the stero goin and the noise stops. Replaced the alternator and it still makes the noise. Hooked up the multimeter to the back of the cd player both red and yellow wires are sitting around the 12.30volt mark I'm stumped any help would be great.
Edited due to spelling mistakes lol
Edited by baggus
use search button for supressor
basically you are getting interference from your power supply
check all earths for your stereo and amp are making good contact
make sure your rcas to the amp are run on the opposite side to the power supply
and get a new noise supressor for the coil and alternator
that should do the job!
cheers guys ive checked all earths and wires and its never had a antenna, rca's are opposite side to battery cable as battery is the boot, will go hunt around for a noise surpressor any idea where ill get one??
lol..i have this problem to with my stock AM radio in the ke55 (turned it on to see if i works the other day)..can't be f@$ked to fix it..never listen to it lol. although mine is a ticking so I'm thinking it the coil somehow...meh...just adding my 2bob
