TDR Posted March 5, 2010 Report Posted March 5, 2010 (edited) hey guys absolute noob question for you :yes: i want to put more diff oil in my ke38 as its sounds like its got none.. where do i put it in? :hmm: and how much do i put in? i realize this might not solve the problem but its worth a try Edited March 5, 2010 by TDR Quote
Taz_Rx Posted March 5, 2010 Report Posted March 5, 2010 Regardless of weather you have a Banjo (jap) or Borg warner (ADM) diff they'll both have a filler plug on the back of the diff. With the car sitting level fill with DIFF OIL (not lsd oil) through this hole until it starts to dribble back out. Small 1lt diff oil bottle will normally have a pull out nozzle in them to make the job a bit easier or you could get yourself one of these to make like even easier. Quote
B.L.Z.BUB Posted March 5, 2010 Report Posted March 5, 2010 shit i put lsd oil in mine cos the dude said it was ok. What a wanker... Quote
Taz_Rx Posted March 5, 2010 Report Posted March 5, 2010 :hmm: It'll still work, but you might want to drain and replace it. Useless info - I bought one of the bottle pumps for $20. Reason is because now I can buy 4L bottles without the pull out nozzle. 1l = $10'ish, 4lt = $25'ish, you do the math. :yes: Also if you do get one of the pumps, they're heaps easier to use when the oil is warn and thinner. Just sit the bottle of oil in a bucket/tub of hot water for half an hour or so before using it. >| Quote
TDR Posted March 5, 2010 Author Report Posted March 5, 2010 just opend it up but it only took about 100ml :yes: ... something else then :hmm: Quote
Taz_Rx Posted March 5, 2010 Report Posted March 5, 2010 Most likely axle bearings. They wear out a whole lot quicker than the diff bearings. Quote
TDR Posted March 5, 2010 Author Report Posted March 5, 2010 Most likely axle bearings. They wear out a whole lot quicker than the diff bearings. hmmm.. its made a whining noise since i bought it, a mate said wheel bearings.. but its gotten a lot worse so i thought maybe no oil in the diff as well. Ive been meaning to go to toyoland to get a new diff drum to drum.. but its probably to far to go in the rolla, might have to get a mate to take me. whats the worse that can happen if i keep on driving it? i am treating it like a grandma too Quote
B.L.Z.BUB Posted March 5, 2010 Report Posted March 5, 2010 (edited) Topping up your diff oil wont work if the other 90% in there is shit. Pop the diff cover off and drain it all then top it up. Mine was making heaps of noise and when i drained it it came out like treacle. Might be the same with yours, you've just diluted it a bit. Worth a try anyway. But like you've said its getting worse and worse so could be something else... And thats the 2nd time my local car supply place has screwed me. Only reason I went back is that I got a voucher. Does the LSD oil have a totally different viscosity? Oh and about the oil pump... a bit of rubber hose and a plastic bottle works sweet if its air tight, just put a rush hole in the side like a bong to let air back in... :yes: cost $0. But thats cos I had to make do. Worked sweet though. Edited March 5, 2010 by blzbub666 Quote
LittleRedSpirit Posted March 5, 2010 Report Posted March 5, 2010 hmmm.. its made a whining noise since i bought it, a mate said wheel bearings.. but its gotten a lot worse so i thought maybe no oil in the diff as well. Ive been meaning to go to toyoland to get a new diff drum to drum.. but its probably to far to go in the rolla, might have to get a mate to take me. whats the worse that can happen if i keep on driving it? i am treating it like a grandma too Wheel bearing most likely will whine pretty constant. Diff will whine different at different load/speed/rpm. Quote
TDR Posted March 5, 2010 Author Report Posted March 5, 2010 it gets louder the faster you go.. once your at 60 its pretty loud, i don't go any faster. Quote
19914afc Posted March 5, 2010 Report Posted March 5, 2010 I work for toyota and we use LSD oil for everything, transfer case oil, non LSD's. So it can't be too bad. Quote
toyota_ae71 Posted March 5, 2010 Report Posted March 5, 2010 deffinetely rear wheel bearing. Mine does the exact same thing. Either buy a radio and turn it up :( or replace them. Or just buy some panadol for your headaches and drive it hard :P Quote
jono1986 Posted March 6, 2010 Report Posted March 6, 2010 So are axle bearings different to wheel bearings? cause my rear end is starting to make noise and was just going to do the diff oil and the wheel bearings Quote
corolla_nut Posted March 6, 2010 Report Posted March 6, 2010 lsd oil is a gl6 grade (obsolete) whereas diff or manual trans oil is a gl5. the difference is the level of shear loading and abuse the oil will put up with, gl6 will put up with more. the thing to be careful of is that EP (extreme pressure oils) have sulfur additives which do not agree with brass, so they will cause problems eventually for your syncrhoniser rings in your gearbox, but they will be fine for your diff... I use LSD oil if I'm on a budget, it is cheaper than the same brand gear/diff oil. I'm using atf in the gearbox at the moment anyway. Robert. Quote
