  Ruts said:
I'm a debadger - if only I could work out how to grind out or fill the corolla lettering in the hatch handle. I'll post a pic and be happy to take suggestions
maybe just sand it off?
its already recessed with raised lettering - so i'd end up with an empty trough along the handle :)
and I don't know if the lettering is hollowed from behind - should pull it off and look i guess
I have done some extensive research on the "AMI" badge on KE20's and have found that it actually stands for "Australian Mental Institution" and your car was badged as such as to warn others of you. I have removed mine.
