KaiShin Posted February 9, 2010 Report Posted February 9, 2010 Hey Guys, Anyone know if the tailshaft from a KE30 will bolt up to a KE55 auto trimatic gearbox? Bolting upto a 4K. Cheers, Kel Quote
curly Posted February 9, 2010 Report Posted February 9, 2010 also any other problems like speedo cables, reverse light switches etc Quote
JiP Posted February 10, 2010 Report Posted February 10, 2010 I'd assume you'd need a KE55 speedo cable and maybe a KE55 speedo. I'd assume you'd need a early KE30 trimatic tailshaft. The box should bolt up fine to the engine. Quote
KaiShin Posted February 10, 2010 Author Report Posted February 10, 2010 Hmm the tailshaft may become a problem then... I have a later model KE30 (78) with the updated Grill and Interior pieces. Ill see if I can confirm if the speedo cable differ in anyway... Thanks for the heads up JiP Quote
JiP Posted February 10, 2010 Report Posted February 10, 2010 Where are you located? Do you already have a KE55 tailshaft? Quote
KaiShin Posted February 10, 2010 Author Report Posted February 10, 2010 (edited) I'm in Brissy northside (Bray Park) I don't have a KE55 tailshaft no... I am hoping it will bolt up to the KE30 shaft (the manual tail shafts are the same as each other I am hoping its the same with the auto). If not I can get a KE55 yoke and get a tailshaft place to put it on the KE30 shaft I guess... Edited February 10, 2010 by KaiShin Quote
JiP Posted February 10, 2010 Report Posted February 10, 2010 Okay thats fine. Offer stands tho. Unless you want to go to kelly's and pay a overrated :wink: Quote
