Raven Posted February 27, 2010 Report Posted February 27, 2010 (edited) Any chance of getting some clear pics of your front mounting setup for the engine? Edited February 27, 2010 by Raven Quote
muv-12a Posted March 1, 2010 Author Report Posted March 1, 2010 Any chance of getting some clear pics of your front mounting setup for the engine? This was taken about 2 years ago when the motor was last out - i'll keep looking for some better pics!!! Quote
Raven Posted March 1, 2010 Report Posted March 1, 2010 Nice :hmm: Thanks heaps! How is the motor mounted to those two mounts there? The 12A I'm getting has a dodgy setup so I need to see how it all bolts up as to what I will need to modify on the RX-7 bracket/mount that bolts to the front of the 12A. Cheers Mick Quote
ausca62 Posted March 1, 2010 Report Posted March 1, 2010 Hi mate, love your work. On the front brake upgrade, can you tell me firstly what master cylinder setup you are running & secondly the PCD of your front hubs. 110mm or 114.4? thanks and keep up the good work. :hmm: Quote
muv-12a Posted March 2, 2010 Author Report Posted March 2, 2010 Nice :blinks: Thanks heaps!How is the motor mounted to those two mounts there? The 12A I'm getting has a dodgy setup so I need to see how it all bolts up as to what I will need to modify on the RX-7 bracket/mount that bolts to the front of the 12A. Cheers Mick I found a couple more pics that should answer your questions in regards to mounting - see below; You can also see that I had no notch away at the cross member to make way for the bottom radiator hose. At some stage I would like to get a nice laser cut version of my crossmember but this one has served me well for over 10 years!! Quote
muv-12a Posted March 2, 2010 Author Report Posted March 2, 2010 Hi mate, love your work. On the front brake upgrade, can you tell me firstly what master cylinder setup you are running & secondly the PCD of your front hubs. 110mm or 114.4? thanks and keep up the good work. :blinks: Thanks mate. I'm using a Ford KB Laser Master Cylinder with a VH40 Remote Booster for the front. PCD all round is 4 x 110mm - i kept it that way because I already had my Simmons!! Cheers! Quote
Raven Posted March 2, 2010 Report Posted March 2, 2010 Cheers for the pics :blinks: Makes more sense now that I can see it all like that. Quote
ausca62 Posted March 3, 2010 Report Posted March 3, 2010 Thanks mate.I'm using a Ford KB Laser Master Cylinder with a VH40 Remote Booster for the front. PCD all round is 4 x 110mm - i kept it that way because I already had my Simmons!! Cheers! thanks mate. On the front was there much you had to do to bolt the discs to the hub or was it a straight bolt up. Like bolt holes line up etc. Thanks again Paul Quote
muv-12a Posted March 7, 2010 Author Report Posted March 7, 2010 thanks mate. On the front was there much you had to do to bolt the discs to the hub or was it a straight bolt up. Like bolt holes line up etc. Thanks again Paul Had to re-drill the rotors to suit 4 x 110pcd and fab a bracket to mount the caliper. Hoppers Stoppers do great kits at a pretty reasonable price. Quote
ausca62 Posted March 7, 2010 Report Posted March 7, 2010 Had to re-drill the rotors to suit 4 x 110pcd and fab a bracket to mount the caliper.Hoppers Stoppers do great kits at a pretty reasonable price. Thanks heeps man. I have been looking for an upgrade for ages but all the others meant running biger than 13" wheels. I have got an excelent supply of 13" race tyres so I wanted to stick with them, Cheers Paul :P Quote
sNoOkDoG Posted August 14, 2010 Report Posted August 14, 2010 guessing you got the engine engineered? how much did it cost? Quote
muv-12a Posted February 13, 2011 Author Report Posted February 13, 2011 Small update, Bought myself a roll cage last week from a Toyota forum member in Melb. It was actually for a KE20 but it fit like a glove!! Was good to get the tools out and work on the car again. Will get a nice drivers bucket seat and harness next, then I'll start planning for fuel injection. Quote
jaygore Posted February 14, 2011 Report Posted February 14, 2011 only just checked your car out and I have to say I'm loving it =] I am torn between sooo many engines for a conversion now... I keep tossing up between rotary, 4agze, sr20det, I look at al the pros and cons of each engine, I just can't make up my mind. However I have always been a rotary fan over all other engines, so maybe this is the one I will ultimately go for... Who knows Quote
carbonboy Posted February 22, 2011 Report Posted February 22, 2011 This car is neat as! I easpecially like the front strut brace that goes around the air cleaner element as I've seen a few where clearance has been a problem :-( Keep up the good work & keep hounding the missus to let you do stuff! Quote
