DR1FT Posted February 1, 2010 Report Posted February 1, 2010 Wondering if i can run a falcon spring in the front end with my ae86 strut setup? My mate is running EL Falcons all round, but without the 86 struts. He has a nice stiff ride all round, my front setup works well for me but back is a bit sloppy. Also looking to raise it up abit so the cut VL fronts have to be changed, thinking falcons ( which model for 86 struts ) Hear is my current set up front end ae86 struts tokico short stroke shocks VL springs vented rotors braided brake lines xt-130 lower control arm t-18 steering knuckles rear end cut falcon springs - seem pretty sloppy compaired to my mates. locked standard diff short stroke shocks. bought the car with this setup already in, so not to sure on the model falcon springs or what not. Cheers, josh Quote
drft_wpn70 Posted February 1, 2010 Report Posted February 1, 2010 just putting this out there but nice rolla man :jamie: Quote
seabiscuit Posted February 1, 2010 Report Posted February 1, 2010 Should be able to if AE86 struts run same diameter spring as KE70! Does your friend with Falcon springs have aftermarket springs? That could be the reason your front end is a bit sloppier.. Or your shocks are buggered! Very cool car! Anything else done to it.. Point us to a project thread? :jamie: Quote
Funking-Awesome Posted February 1, 2010 Report Posted February 1, 2010 Yeah sick car man...I don't usually like orange but that looks alright for some reason! Quote
DR1FT Posted February 1, 2010 Author Report Posted February 1, 2010 Should be able to if AE86 struts run same diameter spring as KE70! Does your friend with Falcon springs have aftermarket springs? That could be the reason your front end is a bit sloppier.. Or your shocks are buggered! Very cool car! Anything else done to it.. Point us to a project thread? :jamie: my front setup is pretty stiff, the rear is pretty sloppy. Nah he got the springs from a wrecker out of a EL Falcon so thinking of trying the same and just cutting them to a daily height, will still be low just not as much. don't have a project thread yet man, trying to get parts sorted out for it still. Cheers Quote
DR1FT Posted February 2, 2010 Author Report Posted February 2, 2010 So can Cut falcon springs be used with 86 struts? Been searching with no clear answer to what model falcon and if it can be done. Quote
