Twitch Posted February 1, 2010 Report Posted February 1, 2010 Hi all, Does anyone have a simple walkthrough for changing the front springs in a Ke55? Cheers - Paul Quote
Evan G Posted February 1, 2010 Report Posted February 1, 2010 jack up car remove wheel crack the top spring hat nut if you don't have a rattle gun this will save ALOT of problems - cut a small section out the brake hose holder on the strut with a hacksaw (so you don't need to undo the brake line/ bleed brakes etc etc) remove the caliper mounting bolts remove 2 bolts on the steering knuckle remove the 3 bolts on the spring hat remove strut Assembly from the car and use a spring compressor then completely remove the spring hat nut when the spring tension is gone Quote
Twitch Posted February 1, 2010 Author Report Posted February 1, 2010 jack up carremove wheel crack the top spring hat nut if you don't have a rattle gun this will save ALOT of problems - cut a small section out the brake hose holder on the strut with a hacksaw (so you don't need to undo the brake line/ bleed brakes etc etc) remove the caliper mounting bolts remove 2 bolts on the steering knuckle remove the 3 bolts on the spring hat remove strut Assembly from the car and use a spring compressor then completely remove the spring hat nut when the spring tension is gone Sweet, thanks mate Quote
Taz_Rx Posted February 1, 2010 Report Posted February 1, 2010 and use a spring compressor then completely remove the spring hat nut when the spring tension is gone I'm going to re-iterate this point for safety reasons. The stock springs are captive and have a bit of tension on them already. If you don't hold this tension back in same way it will release when you remove the top hat....... which is liable to smack you in the face!!! So be warned and careful. :jamie: Quote
