  Taz_Rx said:
That site look European. You should be able to get them through a local dealer and save yourself a massive freight cost. :)
yeah ill give it ago see what i can fine.
are they real brembo's or just a fake rip off brand??
i like them vented as well :D
cheers
Yes they'd be real brembo rotors.
Don't get all excited just because of the brand, they're just replacement rotors. Would be no better than a PBR set.
I haven't had much of a look at the wesite but I dare say you wouldn't be able to get vented ones as KE discs are pretty thin to start with.
yeah I'm up for new rotors anyway mine are to thin!
i was going with the ra40 upgrade but incounted way to many problems
so just leveing stock ke30 brakes but new bearings,rotors,pads and fix up the calipers abit
umm yeah your right ke diskes are only 10mm maybe there not vented :)
as taz_rx has already indicated, the will just be a replacement stock style rotor, that happen to be made by brembo
no different to one that is branded DBA, RDA, etc.
  shauns ke30 said:
Hay guys found these on ebay say's there for a 1.3 ke55????
ebay.
http://cgi.ebay.com.au/Brembo-Brake-Disc-T...=item4ceb65a8ae
http://bremboaftermarket.com/En/Car_Disc_C...rchIsFront=True
Just wanna no has any one got a set from this site????
Are they any good????
Hi... i was also watching this ebay item, but after some looking into, i see that these discs are not vented. they look identical to the factory solid front discs... i contacted a brembo distributor in penrith about these, but they are having trouble identifying the part number in the aussie references they have. if they locate vented discs for ke55 corolla, i shall reply again with info as many corolla owners would like to buy a set. cheers.
Is it worth getting drilled and slotted discs over stock ones, have seen a pair on ebay cheap....is it worth it?
The car is used for a daily driver, but still like to go for cruises through the hills and stuff.
The ones that are for sale are for a later model corolla, but was just going to go to motoquipe and see them for a price. But since everything's pretty much stock apart from the exhaust there's not much point.
I ran slotted solid disks on my torana waaaay back, they made a difference but nothing compared to quality pads. I broke some cross drilled and slotted ones pretty quickly( try 6 weeks!).
The slotted disks warped a little less than the std ones as well but not by much.
All depends on how hard you are on the disks but if you want wank factor go cross drilled but don't lean on them to hard!
Back to the original topic, as parot pointed out, you may end up with the same brand disks for bugger all of the price going local.
If you want it to stop, upgrade to bigger slotted disks, if your happy with it mow just throw some new disks and great pads at it, you won't believe the difference.
JP
