shauns ke30 Posted January 31, 2010 Report Share Posted January 31, 2010 (edited) Hay guys found these on ebay say's there for a 1.3 ke55???? ebay. http://cgi.ebay.com.au/Brembo-Brake-Disc-T...=item4ceb65a8ae http://bremboaftermarket.com/En/Car_Disc_C...rchIsFront=True Just wanna no has any one got a set from this site???? Are they any good???? Edited January 31, 2010 by shauns ke30 Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted January 31, 2010 Report Share Posted January 31, 2010 That site look European. You should be able to get them through a local dealer and save yourself a massive freight cost. :) Quote Link to comment Share on other sites More sharing options...
shauns ke30 Posted February 1, 2010 Author Report Share Posted February 1, 2010 That site look European. You should be able to get them through a local dealer and save yourself a massive freight cost. :) yeah ill give it ago see what i can fine. are they real brembo's or just a fake rip off brand?? i like them vented as well :D cheers Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted February 1, 2010 Report Share Posted February 1, 2010 Yes they'd be real brembo rotors. Don't get all excited just because of the brand, they're just replacement rotors. Would be no better than a PBR set. I haven't had much of a look at the wesite but I dare say you wouldn't be able to get vented ones as KE discs are pretty thin to start with. Quote Link to comment Share on other sites More sharing options...
shauns ke30 Posted February 1, 2010 Author Report Share Posted February 1, 2010 Yes they'd be real brembo rotors. Don't get all excited just because of the brand, they're just replacement rotors. Would be no better than a PBR set. I haven't had much of a look at the wesite but I dare say you wouldn't be able to get vented ones as KE discs are pretty thin to start with. yeah I'm up for new rotors anyway mine are to thin! i was going with the ra40 upgrade but incounted way to many problems so just leveing stock ke30 brakes but new bearings,rotors,pads and fix up the calipers abit umm yeah your right ke diskes are only 10mm maybe there not vented :) Quote Link to comment Share on other sites More sharing options...
silverra23 Posted February 1, 2010 Report Share Posted February 1, 2010 as taz_rx has already indicated, the will just be a replacement stock style rotor, that happen to be made by brembo no different to one that is branded DBA, RDA, etc. Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted February 1, 2010 Report Share Posted February 1, 2010 no different to one that is branded DBA, RDA, etc. ...maybe excluding price!!! :jamie: Quote Link to comment Share on other sites More sharing options...
clubgm Posted March 8, 2010 Report Share Posted March 8, 2010 Hay guys found these on ebay say's there for a 1.3 ke55????ebay. http://cgi.ebay.com.au/Brembo-Brake-Disc-T...=item4ceb65a8ae http://bremboaftermarket.com/En/Car_Disc_C...rchIsFront=True Just wanna no has any one got a set from this site???? Are they any good???? Hi... i was also watching this ebay item, but after some looking into, i see that these discs are not vented. they look identical to the factory solid front discs... i contacted a brembo distributor in penrith about these, but they are having trouble identifying the part number in the aussie references they have. if they locate vented discs for ke55 corolla, i shall reply again with info as many corolla owners would like to buy a set. cheers. Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted March 8, 2010 Report Share Posted March 8, 2010 Mate you're not going to find anybody who makes a vented 12-13mm thick discs. Think about it! :D Quote Link to comment Share on other sites More sharing options...
parrot Posted March 9, 2010 Report Share Posted March 9, 2010 As above, I have a set of PBR standard replacement for the KE15 and they are branded Brembo around the edge. Quote Link to comment Share on other sites More sharing options...
jono1986 Posted April 22, 2010 Report Share Posted April 22, 2010 Is it worth getting drilled and slotted discs over stock ones, have seen a pair on ebay cheap....is it worth it? The car is used for a daily driver, but still like to go for cruises through the hills and stuff. Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted April 22, 2010 Report Share Posted April 22, 2010 Got a link? Cross drilling and slotting is only really for heat dissapation. Quote Link to comment Share on other sites More sharing options...
jono1986 Posted April 22, 2010 Report Share Posted April 22, 2010 The ones that are for sale are for a later model corolla, but was just going to go to motoquipe and see them for a price. But since everything's pretty much stock apart from the exhaust there's not much point. Quote Link to comment Share on other sites More sharing options...
silverra23 Posted April 22, 2010 Report Share Posted April 22, 2010 Drilled is not worth it.. they often crack prematurely. Quote Link to comment Share on other sites More sharing options...
TheNOBBLER[RL] Posted April 23, 2010 Report Share Posted April 23, 2010 I ran slotted solid disks on my torana waaaay back, they made a difference but nothing compared to quality pads. I broke some cross drilled and slotted ones pretty quickly( try 6 weeks!). The slotted disks warped a little less than the std ones as well but not by much. All depends on how hard you are on the disks but if you want wank factor go cross drilled but don't lean on them to hard! Back to the original topic, as parot pointed out, you may end up with the same brand disks for bugger all of the price going local. If you want it to stop, upgrade to bigger slotted disks, if your happy with it mow just throw some new disks and great pads at it, you won't believe the difference. JP Quote Link to comment Share on other sites More sharing options...
