camcam Posted January 30, 2010 Report Posted January 30, 2010 ok ijust brought some rims last night and the off set is alittle f@$ked it rubs onthe bottem of the strut i was expecting rub but not on that ahhh how can i fix this proplem woth out massive bolt on spacers because i don't feel like flairing my gards out any help would be appreiated cheers cam Quote
altezzaclub Posted January 31, 2010 Report Posted January 31, 2010 Nope- you're stuffed! If I understand you correctly, the side of the tyre rubs on the strut, so it has to be moved away outwards. So, spacers will do it, bending the strut to give +ve camber will do it, and if its the tyre not the rim, then narrower tyres might do it. If there is another hub that fits the bearings, the disc and the rim bolts AND moves it outwards you'll be in luck. but otherwise just sell the rims and get a different offset. Spacers do stress the rim studs so anything over 10mm means it has to carry its own studs, and outwards offset stresses the stub axles although I've only heard of Hondas snapping stub axles from wide rims. Did you do any work on how they will affect your handling, steering weight, turning circle and ackerman setup? That can sometimes go to shit with wide rims that move the centerline. Quote
camcam Posted January 31, 2010 Author Report Posted January 31, 2010 altezzaclub said: Nope- you're stuffed! If I understand you correctly, the side of the tyre rubs on the strut, so it has to be moved away outwards. So, spacers will do it, bending the strut to give +ve camber will do it, and if its the tyre not the rim, then narrower tyres might do it. If there is another hub that fits the bearings, the disc and the rim bolts AND moves it outwards you'll be in luck. but otherwise just sell the rims and get a different offset. Spacers do stress the rim studs so anything over 10mm means it has to carry its own studs, and outwards offset stresses the stub axles although I've only heard of Hondas snapping stub axles from wide rims. Did you do any work on how they will affect your handling, steering weight, turning circle and ackerman setup? That can sometimes go to shit with wide rims that move the centerline. I'm going to put 175 \65s on it because its got 195on there now see wharts that like ??? give it a shot Quote
Funking-Awesome Posted January 31, 2010 Report Posted January 31, 2010 camcam said: I'm going to put 175 \65s on it because its got 195on there now see wharts that like ??? give it a shot Wow 195s...Thats wide. I have got 175 with 8mm spacers on my car. Quote
mungi mods Posted January 31, 2010 Report Posted January 31, 2010 anything with grater than +27 offset in a 7 will scrub on the strut, bolt on spacers ...15 mm and roll the guards if they need it i have run 15 x 7.5 +2 front with 195/50with a light roll Quote
camcam Posted January 31, 2010 Author Report Posted January 31, 2010 mungi mods said: anything with grater than +27 offset in a 7 will scrub on the strut,bolt on spacers ...15 mm and roll the guards if they need it i have run 15 x 7.5 +2 front with 195/50with a light roll problem solved was the big ass tires that was on there grabin 5 mil spacers tonight running 175 65 14 on front and then the 195 65 14 0n back lmao :) cheers all cam cam Quote
ke70dave Posted January 31, 2010 Report Posted January 31, 2010 do you have the exact specs of the wheels? cause 195 isnt exactly that big for a ke70, its like the perfect size for 15" on a ke70 i reckon your wheels are 5-6" and quite a positive offset... Quote
camcam Posted February 4, 2010 Author Report Posted February 4, 2010 ke70dave said: do you have the exact specs of the wheels? cause 195 isnt exactly that big for a ke70, its like the perfect size for 15" on a ke70 i reckon your wheels are 5-6" and quite a positive offset... don't know there all good now i have 175 tires on it so ;) Quote
