what 5 stud pattern do you wanna convert to?
Going by whats in his thread, Curly has used MX73 cressida struts in his KE38 (KE55 wagon)
Edited by SLO-030
for the cost involved to fit commodore struts in, I think you'd be better off using the hopper stoppers kit, available in any pcd you like.
when you factor in the costs of buying commodore struts, then modifying them to suit (shortening, reconditioning, ect) it would probably be cheaper to just use hoppers kit.
I would also reccomend using the ford stud pattern, as the wheel selection is much broader.
XT130 struts, VB-VP integral hub rotors and a pair of SW13B Hilux calipers and your set.
RA40 steering arms, KE30/55 spring hats/ strut tops and its all bolt in.
All that would be left it to convert to coilover or have a spring made to suit the Corona perch and KE spring hat.
Edited by SLO-030
  • 2 years later...
sorry for the thread mining...... do you have any pics of this set-up? is it all bolt on or any little tricks?
