curly Posted January 23, 2010 Report Posted January 23, 2010 post your dyno sheets here quoting model of corolla engine used na or boosted modifications fuel used etc Quote
LittleRedSpirit Posted January 23, 2010 Report Posted January 23, 2010 (edited) AE101 Silvertop 4age Blacktop Quads and flywheel 4.1 Borg Warner open centre Jap T50 Adaptronic. VVT off at around 6000 rpm. In an AE71 Edited January 23, 2010 by LittleRedSpirit Quote
Hiro Protagonist Posted January 23, 2010 Report Posted January 23, 2010 AE82 Twincam Seca 7-rib pigport 4AGE Catback exhaust Note AFRs were all over the place due to lack of intake air-temp sensor, plus god-knows how many wiring gremlins and mis-matched components (was probably the 3rd different engine that the car had had over it's lifetime, including a stint with a GZE) AE102 sedan 7AFE CAI, exhaust By this time next year I hope to have a lot more power, but still staying NA :dance: Quote
1JZKe55 Posted January 24, 2010 Report Posted January 24, 2010 ke55 4 door 5k wolf 3D EFI sc14 supercharger and intercooled Quote
curly Posted January 24, 2010 Author Report Posted January 24, 2010 (edited) 80 model KE38 wagon Edited September 14, 2010 by curly Quote
Taz_Rx Posted January 25, 2010 Report Posted January 25, 2010 4ktc TD04-L turbo and 8PSI..... and the 5kte setup with T25G on 10 PSI. Circle is around the visible clutch slip..... Quote
leigh Posted January 25, 2010 Report Posted January 25, 2010 5k Headwork cam twin side webers extractors BP ulitmate Quote
the_van_can Posted April 28, 2010 Report Posted April 28, 2010 Hay all, This is my dyno sheet for my pano, Stock 4age 16 valve smallport done well over 200,000 EMS ecu 1 external fuel pump as my fuel system, has been upgraded since. funny thing too is that my throttle kept hitting on the holder bracket because of the cut and shut inlet and the throttle only opened about 75% probably got a crap tune now I've fixed that Quote
Trev Posted April 28, 2010 Report Posted April 28, 2010 Step aside for the HI HP warriors :) AE82 twincam auto, Pod & extractors with mild zorst. Yes I know, Ularu, I had the wrong parameters set when I printed it. Quote
13BT_KE20 Posted April 28, 2010 Report Posted April 28, 2010 (edited) KE20 13BT 10psi PULP printer wasnt working so this is the best i could do Edited April 28, 2010 by 13BT_KE20 Quote
Hiro Protagonist Posted April 28, 2010 Report Posted April 28, 2010 Step aside for the HI HP warriors :) AE82 twincam auto, Pod & extractors with mild zorst. Yes I know, Ularu, I had the wrong parameters set when I printed it. Award for most useless axis on a dyno graph yet goes to boost on an NA engine :lol: (not that it was of your doing) Quote
Trev Posted April 28, 2010 Report Posted April 28, 2010 Award for most useless axis on a dyno graph yet goes to boost on an NA engine :) (not that it was of your doing) Ha it actually was me, It was the 1st time I had used the dyno by myself, Yes I know, Ularu, I had the wrong parameters set when I printed it. It was making 75hp in 1st gear too. Quote
Twinky Posted April 28, 2010 Report Posted April 28, 2010 My bro took my car down to get it dyno'd a while back. The red trace is with the silencer in the exhaust off and the blue trace is with the silencer on. They have done some wiered overlay thing where the red trace is actually ment to be over the blue trace but they have offset it. So imagint the dots being on top of one another rather than two spaces apart. Car : AE82 Series 2 Twin Cam Engine : 20v Silvertop N/A Transmition : 5 speed C - something or other Mods : Pod filter, Lightened flywheel, uber wikedness. The run was done in third gear Quote
Johno Posted May 1, 2010 Report Posted May 1, 2010 model of corolla: AE82 Sedan engine used: 4age Bigport 16v, stock na or boosted: NA modifications: 2" exhaust, hi flo cat, turbo muffler fuel used: Mobile 98 octane Quote
RicZ Posted June 13, 2010 Report Posted June 13, 2010 model of corolla: KE35 engine used: 2TG na or boosted: NA - Twin 42MM Webbers modifications: Pacemaker Extractors, 2" exhaust, fuel used: 98 Octane (78RWKW) Dyno.pdf Quote
