rhys2229 Posted January 11, 2010 Report Posted January 11, 2010 hey i'm in the process of gathering parts for a 4k to 4age conversion, i need some info on the fuel pump and lines, i'm thinking of using a vl turbo bosch style electric pump (probably cheapo copy), do i need to use a lift pump in the tank as well? or can i just run the electric fuel pump straight from the tank (after a fuel filter)? and where do i get the metal fuel lines from the tank to the engine bay? thanks Quote
kiahn Posted January 11, 2010 Report Posted January 11, 2010 OPTION 1: 6mm lines for feed and return bosch 044 (VL Turbo) fuel pump standard ryco efi fuel filter in engine bay and an inline one before the pump DO NOT expect it to supply fuel when running under 1/4 of a tank OPTION 2: 6mm feed and return lines lift pump into the swirl pot with filter before the pump then a bosch 044 to a filter then to your engine 2nd option is harder but 100 times better as it wont cut out under heavy right hand corners Quote
rhys2229 Posted January 12, 2010 Author Report Posted January 12, 2010 is the tank in an ae71 different from a ke70 because my mate has just a vl external pump and it seems to run ok without a surge tank and lift pump, Quote
ke70dave Posted January 12, 2010 Report Posted January 12, 2010 (edited) ooh ooh i can answer this!! currently re-hashing my fuel system at the moment. i ran my 4age on just a bosch 070 (vl pump) external fuel pump (no lift pump) for a few months. it did run well, but after about 45mins the pump would get VERY noisy, and it would drive me up the wall. high pressure pumps are not designed to suck fuel, so i think they start to cavitate after a while. also contrary to popular belief, if i drove sedately i could run my fuel tank REALLY low (fuel light on for yonks....) without it surging. it was only when i got "enthusiastic" that it would surge. i then installed a surge tank setup, and made this tech article: http://www.ae86drivingclub.com.au/forums/s...read.php?t=8255 have a read. i have had that setup in my since that tech article (a little over 8months). been going great. however i believe my lift pump has died/is dying. so thus i am changing my setup a bit. i am going to install a lift pump from the VL commodore inside my tank. the standard VL setup is a lift pump inside the tank, which feeds the external high pressure pump. this means that the lift pump must flow more than the high pressure pump (for your information the bosch 070 flows 130L/hour @ 3bar). what i am going to do, is use this internal fuel pump to fill up my surge tank. and the use my bosch 070 from the surge tank to the engine. and because my lift pump will flow more than my high pressure pump, i will be able to put the return from the engine straight back into the tank. this should help with fuel heating issue (which i suspect i had as well....) but since i have a surge tank between the lift pump and the high pressure pump that should stop any surging issues. here is how to install the lift pump into an ae86 tank (should be similar to ke70 i'm hoping): http://www.rollaclub.com/faq/index.php?tit..._AE86_Fuel_Tank so in short. buy a lift pump (mine cost 91$) buy a small surge tank (mine was 99$) and say good by to surge issues, and hello to a nice neat fuel pump setup. and just use the standard metal lines, they are big enough. also in response to kiahn. do not use a bosch 044. they flow 200L/hour @ 5bar. it is an absolute complete over kill (standard jap ae86 has an 80L/hour pump) i ran one in my car recenently trying to diagnose a problem, and my fuel pressure regulator could not handle the flow and also it was heating up my fuel sooo much that i was getting a vapor lock issue (google it, its very interesting). my fuel was getting so hot that my surge tank was essentially untouchable after a 30min drive. Edited January 12, 2010 by ke70dave Quote
rhys2229 Posted January 13, 2010 Author Report Posted January 13, 2010 where did you buy your surge tank? ebay have alot but most are probably too big as they hold 2 litres. do parts shops stock them? Quote
ke70dave Posted January 13, 2010 Report Posted January 13, 2010 i bought this one http://www.tweakit.net/shop/product_info.p...h623r2dq3ab3tt0 Quote
rhys2229 Posted January 15, 2010 Author Report Posted January 15, 2010 (edited) and how did you wire up the two pumps? from the battery with a fuse? Edited January 16, 2010 by rhys2229 Quote
ke70dave Posted January 17, 2010 Report Posted January 17, 2010 circuit opening relay with the ECU. have a google around, its the standard setup for the 4age. ensurs your pumps turn off when you your engine turns off. wire them both off the same output. just make sure you use a chunky main power feed. Quote
