toyota_ae71 Posted January 5, 2010 Report Posted January 5, 2010 Mighten be toyota powered but it still amazed me :S Quote
KENut Posted January 6, 2010 Report Posted January 6, 2010 love ke70 said: very interesting Seconded. Setting up that in such a small car, weight?/track/wheelbase would be quite a challenge. Would like to see some track footage of it Quote
TE278U Posted January 6, 2010 Report Posted January 6, 2010 where's the driveline info? i couldn't see anything that mentioned it was 4wd at all? Quote
irokin Posted January 6, 2010 Report Posted January 6, 2010 TE278U said: where's the driveline info? i couldn't see anything that mentioned it was 4wd at all? I seriously doubt its 4wd too unless I see some undercar shots. Its just the dyno setup, the rollers are linked so that ABS/traction control/active stability systems don't crack the shits when the front wheels aren't turning. Still a pretty sweet setup. Quote
Xany Posted January 6, 2010 Report Posted January 6, 2010 ^^^^^^^^ Exactly what i thought too Ben. Plus the fact the car squats as if its RWD only when on power. Quote
Hiro Protagonist Posted January 6, 2010 Report Posted January 6, 2010 irokin said: I seriously doubt its 4wd too unless I see some undercar shots. Its just the dyno setup, the rollers are linked so that ABS/traction control/active stability systems don't crack the shits when the front wheels aren't turning. Still a pretty sweet setup. Plus note how the front tyres are noticeably narrower than the rears, a la front-runner drag style, which would highly stupid for a high-powered 4WD set up Quote
orangeLJ Posted January 6, 2010 Report Posted January 6, 2010 Is it just me, or does that dyno look ridiculously hard to put a car on? single large rollers instead of dual rollers for each wheel? or is there something I'm missing? Quote
