TheNOBBLER[RL] Posted January 24, 2010 Report Posted January 24, 2010 He got them... Terrible idea that is! Were still on the GOR Cruise so he will probably post them after we get back on Tuesday. JP (Nobby) Quote
dfunkt Posted January 27, 2010 Report Posted January 27, 2010 while they're uploading, i'll give you a quick run down on what you can do to fit a ke30 grill to a ke10. Cut a few inches from it and "plastic weld" it back straight to remove the extra width it has over a 10 front end. Completely remove the front of the 10 and weld on the entire front of a 30 (making sure you remove the extra width of the 30 front end again) and i'm not going to bother about all of the mounting points that need to either be removed or made to accomodate the 30 grill, as i'm sure you've already worked those out. and now the pics.... Centered across the front. Passenger side aligned with the headlight. and showing the different width at the drivers end. now i shall remove myself from this horrid idea.....let us never speak of it AGAIN! dF Quote
